Painting Over Backing After Removing Vinyl Wallpaper - Painting - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 11:30 PM   #1
Painting over backing after removing vinyl wallpaper
My living room has some very poorly attached vinyl wallpaper (I can remove it with my bare hands). It's also ugly, so down it goes.
Under it is a papery yellow backing. I tried steaming it off to get to the plaster underneath, but it barely responded at all. I'm considering just painting over it. Can I do that? If so, what's the best way to prep it? It's got a good bit of texture to it.
Image of the paper backing, with some old wallpaper on the side:
http://goo.gl/I28YK
Close-up of the paper backing:
http://goo.gl/P9iIH
Thanks!
zachinqueens is offline   Reply With Quote
Old 10-01-2011, 11:42 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Your close up looks like clay based paper paste. You should try to get it off- it will just cause problems and look ugly too.
Do a search for paper stripping- it's been talked about often.
Basically get it real wet with a sponge or a pump sprayer, and have patienc3- wait intil it is soft and scrape most off with a 4 or 6" putty knife. Use a very rough scrubbie and sponge to get the rest off.
report back on how that goes.
And read up on what to do next..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-02-2011, 12:27 AM   #3
Zach, I agree with brushjockey. It will come off, but it will take a bit of effort. You basically need to turn it to mud and scrape it off. Trust me, I feel your pain. I did what amounted to most of a house that had clay paste. You're fortunate you have plaster. I had to damage the drywall quite a bit with the water necessary to remove. Good luck with it.
Old 10-02-2011, 05:41 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
As said, it needs to come off and it being plaster, it will come off.
http://www.wallpaperinstaller.com/wa...stripping.html
Old 10-02-2011, 10:10 AM   #5
Gymschu's Avatar
Rewards Points: 476
If you don't take it off, the water in your latex paint will reactivate the clay ADHESIVE and leave you with soup on your walls! Don't take any shortcuts, PLEASE!
Old 10-02-2011, 06:00 PM   #6
chrisn's Avatar
Rewards Points: 228
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (10-04-2011)
Tags
backing , painting , priming , vinylwallpaper , wallpaper
Painting vinyl siding... can it be done??? simiesue Painting 11 07-05-2011 04:50 PM
Removing vinyl siding from cedar mikegyver Carpentry 1 02-17-2011 08:47 PM
Removing wallpaper and then painting applesusan Painting 7 02-24-2008 05:32 PM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
painting over wallpaper derose Painting 4 09-02-2006 03:56 PM
