Painting over 4 year old primer coat
Greetings all!
My first post to this forum: I finished buliding a house 4 years ago...due to other projects and lack of time I never painted the walls and ceilings. The drywall just had a sand-textured primer coat sprayed on it by the drywall subcontractor. Anyway, now I'm getting ready to paint it. One of the guys at one of the paint stores said that I should probably reprime the walls since the old primer has likely "degraded" and is not sealing the wall like it would if it were new. Have any of you ever heard of this before? Needless to say, this was not welcome news. I was hoping that I could just dust off/vacumn the walls real good and have at it. I'd appreciate any advice. Jim |
Take some regular (yellow) masking tape, stick it to the primer, and pull it off quickly. If the primer comes off with the tape, then it wasn't backrolled, and that primer isn't sticking well to the walls (and ceilings too, prolly). Quote:
PS: "Brownian Motion" is named after the English botanist Robert Brown, who noticed that tiny pollen grains floating in water would appear to slowly move about when viewed under a microscope. Einstein investigated this phenomenon and was able to show that the pollen grains moved the same way as an object of equal mass would when it was being bounced around by the random impacts of much smaller objects. (That is, O2, N2 or H2O molecules hitting the pollen grains would make the pollen grains move.) Einstein reasoned that very tiny particles (like soot from burning candles) behave very much like large molecules, and would move when O2 and N2 molecules in the air bump into them. Similarily, such tiny particles would lose energy when they bump into a cold wall. And, when they lose energy, they stop moving and remain on the surface of that cold wall. THIS is why dirt and dust will accumulate over the studs on an exterior wall, and accumulate most heavily right over top of where the drywall nails or screws are located, cuz that's where the wall is coldest. Ya gotta know about Brownian Motion to get your DIY'er arm badge in Painting. If you don't see any such lines on exterior walls, then I'd be inclined to just paint over what you have. If you do see parallel lines of dirt over wall studs and ceiling joists, then you really should clean them off before painting. http://www.aip.org/history/einstein/brownian.htm PS2: And, truth be known, it's too bad that you have to go so much smaller than airborne dust particles for quantum effects to become important. Otherwise we'd probably know more about the world we live in than we do. |
Great! Thanks for the reply! I did the tape test....it seems fine.
May you always have the Brownian Motion where you need it! Jim |
If this was an exterior job, the bit about the primer "degrading" might make sense. But not in an interior, unless there has been actual damage or staining done to the primer. Certainly, if the primer has been extensively scrubbed or if it is stained, you will need to fix that up; but otherwise there is no need to reprime.
SirWired |
The old primer will be extremely "thirsty" and tough to paint and easy to flash
I'm the first to speak out against over-priming, but in this case absolutely prime first |
Slickshift:
What would change in the primer over 4 years that would require it to be re-primed? If oil based and latex paints last well over 4 years between coats, why would the old primer need a new coat? |
| All times are GMT -4. The time now is 05:20 PM. |
