Painting Outdoor Wood Table - Painting - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 03:26 PM   #1
Hello, I have built a fold able wood table to take to tailgates and camping. This table will be strictly used outdoors. I'm wanting to paint the surface with my college colors (FSU) and include a mascot in the center. I definatley want to protect it with some type of polyurethane or lacquer. Is there a better type of paint to use, or does certain types of paint work better with polyurethane?
As you can probably tell, I'm new at this. I'm having an artistic friend paint the table, but I wanted to make sure we used a type of paint that would last and that we could protect it as long as possible.
bwilliams320 is offline   Reply With Quote
Old 08-28-2009, 09:04 AM   #2
you can apply Spar Varnish over the paint to help protect it. Or just use exterior paints.
I have clear coated over paint on some cornhole boxes and they are 3 years old and still in good shape (i do not leave them out).
let your paint cure before you apply the Spar Varnish. you may have to wait 30 days to be safe. apply 2 to 3 coats of varnish sanding between coats.
NAV is offline   Reply With Quote
Old 08-28-2009, 08:43 PM   #3
First-time Home Owner
Just use exterior paint, then there's no need to varnish.
ciera is offline   Reply With Quote
outdoor , paint , polyurethane , protectant
Super glaze bar table finish jlwiu1 General DIY Discussions 18 02-05-2016 03:52 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 07:44 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
