Painting Out Filler - Painting - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 11:22 AM   #1
painting out filler
I have a client who wanted me to install a little over 500' of crown moulding in his home - all in. (caulked, filled, painted) I generally don't do that as I am not a painter (ok I suck at it!) but times being slow....
so I bought a spray paint pressure pot/thingy - sprayed it all in my garage. It came out looking pretty good! not outstanding but ?
anyway, installed it, filled the nail holes with dyna patch. Came back, sanded that, then brushed paint over top.
Here's the problem - when you look long way's at the crown, (natural light) you can see "dull" spots where we put the filler! (semi-gloss latex, $35/gallon)
so I decided to just paint the whole surface- brush. We did that, and while it helped a little bit, you can still see the "dull" spots! grrrrr
so I've done something wrong here, but I don't know what it is! The client doesn't see it, he's happy, but I am not- I'm not going to fiddle with the current job anymore, but for future jobs it would be nice to be able to solve this problem.
semi-gloss is not my friend!!!!! next time it'll be eggshell....
thx
Laurie.
www.lauriescustomfinishing.ca
mrmac204 is offline   Reply With Quote
Old 04-09-2010, 11:53 AM   #2
Rewards Points: 526
The filled spots have to be primed/sealed otherwise they will absorb the finish coat at a different rate than the rest of the substrate and create areas that flash. Using a paint with less sheen will make the flashes less obvious but sealing them is the only solution.
Windows is offline   Reply With Quote
Old 04-09-2010, 12:43 PM   #3
Jay123's Avatar
Jay123 is offline   Reply With Quote
Old 04-09-2010, 06:28 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
what he said
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
do not use concrete filler to fill stones... KUIPORNG Landscaping & Lawn Care 4 08-29-2008 05:16 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
