Old 05-01-2007, 10:52 AM   #1
Painting OSB in the garage.
Hey guys,
Want to cover the walls in my garage with 7/16" OSB instead of drywall (cheaper, can screw into it).
I've seen OSB that has been painted and it looks terrible. Not smooth at all and the 'chips' of wood really show through.
I'm looking for an affordable process that will allow me to 'seal' the surface and cover up some of the irregularities of the OSB. Then cover coat with an affordable interior paint.
I would like to be able to paint and have it look like reg plywood, and not OSB. I don't mind the seams between the sheets of wood, I can handle that.
Thanks for any advice.
Tim
timg is offline   Reply With Quote
Old 05-01-2007, 11:37 AM   #2
They're all fixer-uppers
J187's Avatar
If the OSB you get has a smooth side, install it w/ that facing inside the garage. I dont' think you'll have much like sealing it smooth, but a good oil based primer like kilz and a couple coats of paint should get you as a good of results as you could expect. You could cover seems w/ cheap molding too if you like.
J187 is offline   Reply With Quote
Old 05-01-2007, 11:50 AM   #3
Mod / ArchiBuilder
Cole's Avatar
Cole is offline   Reply With Quote
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Painting inside of garage door PUNISHER VETTE Painting 10 07-11-2007 12:06 AM
Painting Garage dmartslc Painting 5 04-01-2007 04:03 PM
Painting drywall in garage Rod Painting 5 08-12-2005 07:36 PM
