Painting OSB - Painting - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 02:16 PM   #1
Painting OSB
I just finished the interior of my garage using 7/16 OSB. (hey, it's just a garage) I'd like some recommendations on primer to use. The garage is heated with a woodstove periodically, otherwise cold. I also used galvanised nails so the heads wouldn't rust, so a latex is fine, if that's what's required.
bushmoose is offline   Reply With Quote
Old 01-22-2011, 03:55 PM   #2
Gymschu's Avatar
Rewards Points: 930
I'd use B-I-N, the water-based version with the blue label......good overall primer that will seal up the OSB.
Gymschu is online now   Reply With Quote
Old 01-22-2011, 06:06 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 472
Bin would work but it is hardly neededfor this project. Here is a good less expensive alternative.
Old 01-23-2011, 08:59 PM   #4
Thanks fella's!
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
