-   -   Painting OSB (http://www.diychatroom.com/f4/painting-osb-93127/)
bushmoose 01-22-2011 02:16 PM
Painting OSB
I just finished the interior of my garage using 7/16 OSB. (hey, it's just a garage) I'd like some recommendations on primer to use. The garage is heated with a woodstove periodically, otherwise cold. I also used galvanised nails so the heads wouldn't rust, so a latex is fine, if that's what's required.
Gymschu 01-22-2011 03:55 PM
I'd use B-I-N, the water-based version with the blue label......good overall primer that will seal up the OSB.
chrisn 01-22-2011 06:06 PM
1 Attachment(s)
Bin would work but it is hardly neededfor this project. Here is a good less expensive alternative.
bushmoose 01-23-2011 08:59 PM
Thanks fella's!
