Painting An Old Varnished Wooden Bookshelf - Painting - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 04:39 PM   #1
Question
Painting an old varnished wooden bookshelf
Hi all, first post. Longtime lurker here.
My folks remodeled their house recently and gave me a bookshelf they had in their closet. It's about 7.5' tall and made of varnished pine with a plywood back. My dad used varnish for everything back then.
Anyway, I'd like to lay it on its side, build a molding-trimmed base for it, and use it as a sofa table.
It is probably 30 years old and solid as a rock. I'd like to paint the whole thing, but I'd appreciate some advice on the best procedure. Being pine, it has a couple of knot holes and some other irregularities that would disrupt a nice painted surface.
Should I use some of the "liquid sandpaper" first? I was thinking about using drywall compound after prepping the surface and/or sanding. I can also go either way on water-based or oil-based paint. I have a HVLP gun and some brushes.
Thanks for any advice. I'll be sure to post pics of the final product.
speckledpig is offline   Reply With Quote
Old 07-02-2012, 05:41 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Lightly sand, clean, apply GOOD bonding primer( Cover stain, Bullseye 123), paint with whatever, 2 coats
Old 07-02-2012, 07:07 PM   #3
Thank you.
There is one significant knot hole I am worried about. Maybe 1" across.
Could I put some bondo in it, or am I just asking for trouble. The other idea I had was a drywall patch kit and just compound and sand it smooth.
Old 07-02-2012, 07:36 PM   #4
liscenced electrician
Rewards Points: 538
if the hole goes all the way through i would first use fiberglass to fill the hole and then use bondo or plaster (like fixall, not drywall mud) to smooth it out
jimmy21 is offline   Reply With Quote
Old 07-02-2012, 09:40 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
Bondo or similar- use jimmy's idea- although I would just underfill it slightly and use something like Elmers wood filler to top off to sand.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-03-2012, 04:56 AM   #6
chrisn's Avatar
Rewards Points: 228
Originally Posted by speckledpig View Post
Thank you.
just adds character to the piece
Old 07-03-2012, 11:27 AM   #7
Great, but my wife doesn't want character... :D
Thanks all.
Painting old wooden garage doors ingebondi@yahoo Painting 9 04-01-2012 01:32 PM
Painting wooden columns...need to prime? swaff Painting 6 06-07-2011 11:27 AM
painting wooden furniture? dawg803 Interior Decorating 5 04-26-2011 08:03 PM
painting a newly made wooden bench sdristau Painting 0 08-14-2010 08:13 PM
Painting Wooden Chair for outdoor use Wanda General DIY Discussions 2 08-24-2007 09:48 AM
