-   -   Painting an old varnished wooden bookshelf (http://www.diychatroom.com/f4/painting-old-varnished-wooden-bookshelf-148946/)
speckledpig 07-02-2012 04:39 PM
Hi all, first post. Longtime lurker here.
My folks remodeled their house recently and gave me a bookshelf they had in their closet. It's about 7.5' tall and made of varnished pine with a plywood back. My dad used varnish for everything back then.
Anyway, I'd like to lay it on its side, build a molding-trimmed base for it, and use it as a sofa table.
It is probably 30 years old and solid as a rock. I'd like to paint the whole thing, but I'd appreciate some advice on the best procedure. Being pine, it has a couple of knot holes and some other irregularities that would disrupt a nice painted surface.
Should I use some of the "liquid sandpaper" first? I was thinking about using drywall compound after prepping the surface and/or sanding. I can also go either way on water-based or oil-based paint. I have a HVLP gun and some brushes.
Thanks for any advice. I'll be sure to post pics of the final product.
chrisn 07-02-2012 05:41 PM
Lightly sand, clean, apply GOOD bonding primer( Cover stain, Bullseye 123), paint with whatever, 2 coats
speckledpig 07-02-2012 07:07 PM
Thank you.
There is one significant knot hole I am worried about. Maybe 1" across.
Could I put some bondo in it, or am I just asking for trouble. The other idea I had was a drywall patch kit and just compound and sand it smooth.
jimmy21 07-02-2012 07:36 PM
39 Attachment(s)
if the hole goes all the way through i would first use fiberglass to fill the hole and then use bondo or plaster (like fixall, not drywall mud) to smooth it out
Brushjockey 07-02-2012 09:40 PM
Bondo or similar- use jimmy's idea- although I would just underfill it slightly and use something like Elmers wood filler to top off to sand.
http://ep.yimg.com/ca/I/yhst-7729080...214_1107427398
chrisn 07-03-2012 04:56 AM
Originally Posted by speckledpig (Post 956395)
Thank you.
just adds character to the piece:yes::whistling2:
speckledpig 07-03-2012 11:27 AM
Great, but my wife doesn't want character... :D
Thanks all.
