Painting Old Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 01-29-2006, 01:38 PM   #1
painting old cabinets
We have cabinets that seem to have wax on the wood. It builds up around the doorknobs and makes the cabinets look bad. I tried some chemical strippers and none of them do anything. Now I am thinking of painting over it.
Do I need to sand the cabinets first? They are darkwood stained.
Do I have to get rid of all the wax first? Seems blended into the surface except is not noticeable except around the doorknobs.
Do I need primer first? etc.
Any help is appreciated.
pdagosta is offline   Reply With Quote
Old 01-29-2006, 10:12 PM   #2
kbdesigns's Avatar
Clean the cabinets with TSP or equivalent, then sand. Use a good quality primer like Zinsser and %100 acrylic paint.
kbdesigns is offline   Reply With Quote
Old 01-30-2006, 12:39 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
My Ideal Cabinet Repaint:
Clean with ammonia/water solution
Let dry
Sand with 180
This is to rough up the surface, not sand it off
Wipe with Tack Cloth
Prime with shellac based primer*
Let dry
Sand with 180
This is a light sanding to smooth out the shellac a bit
Wipe with tack cloth
Paint first coat, with a proper brush, quality oil-based**, high gloss paint
Let dry over night
Sand with 220
Second coat quality oil based** high gloss paint, also with a brush
Enjoy beautiful cabinets
* I recommend Zinsser's BIN, and as with any shellac, have a source of fresh air and wear a respirator rated for fumes
** A high quality water-born enamel can be substituted, in fact it's recommended for people not familiar with working with oil paints, or worried about more fumes or clean up solvents used for oils
slickshift is offline   Reply With Quote
Old 02-02-2006, 03:52 AM   #4
747
registered
747's Avatar
Rewards Points: 534
Wow your bigtime slickshift for recomending shellac. To the original poster. Have you got a garage you could paint in or are you in a warm weather climate where you could paint outdoors. I would recomend taking all the doors off not a big deal get cordless drill taking drawers out and doing like slickshift says. Also take it one step futher by updating the hardward. Make sure you put something over your nose and mouth before messing with the shellac.
ps. Slick still waiting for you to tell me how to proceed on the fireplace.LOL
747 is offline   Reply With Quote
Old 02-05-2006, 09:04 AM   #5
slickshift's Avatar
lol
I like the shellac because it works...always
It stops tenacious bleed through and sticks to almost anything like bubblegum in a kid's hair
It's there...period
You can use an oil-based primer
...and on some projects I do
It's just that with some unknowns (w/o seeing it) I know the shellac will work, so I'm confident in my recommendation of it
On my cabinets I would use shellac for the durability
I want to be able to wack them with the butt end of my putty knife and not have the paint chip
...it won't
...the fireplace?
Old 08-10-2006, 07:51 PM   #6
Let dry
Sand with 180
Let dry
Sand with 180
Let dry over night
Sand with 220
what white paint would you recommend for the cabinets? I like the results in this photo.
skittlzski is offline   Reply With Quote
Old 08-11-2006, 05:29 AM   #7
slickshift's Avatar
Those seem pretty shiny
I'd suggest Ben Moore's Impervo, either waterborne or oil, whichever you are comfortable with, in the highest gloss available
Off-hand from the pics it looks like it might not quite be as glossy as those
But for a super glossy finish the step up to Fine Paints Of Europe's Dutchlac is not a step I'd undertake lightly
It's very difficult to work with
The Impervo is great to work with
Old 08-11-2006, 07:45 AM   #8
number the cabinet doors when you take them off. Makes it easier to reinstall.
redline is offline   Reply With Quote
Old 08-11-2006, 07:49 AM   #9
I agree they are quite glossy. I don't think I want them that glossy. Do you still recommend the hightst gloss Impervo?
Old 08-11-2006, 09:16 PM   #10
slickshift's Avatar
The Satin Impervo ("satin" is BM's "semi-gloss") is the best choice for cabinets IMO
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Worth removing the cabinets before painting my kitchen? J187 Painting 7 10-08-2006 08:02 PM
Painting Kitchen Cabinets bgillette79 Painting 1 09-08-2006 05:31 AM
Painting Cabinets Leenders Painting 4 04-17-2006 01:19 PM
