Painting OBS Garage?? - Painting - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 08:24 PM   #1
I recently framed out a 30 by 40 pole shed and I then put up OSB sheeting. I would like to paint this and I am wondering what the best method is? Would this need to have a coat of primer on it? What is the best paint for this type of accplication? Brands you would suggest? Interior / Exterior? Water or Oil based? Roller / Sprayer application? Any information would be helpful and appreciated. I am sure you pay for what you get but I was wondering if any one ever used a Wal-mart brand paint? Thanks for your help.
two shot is offline   Reply With Quote
Old 10-09-2008, 08:30 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Nothing is good for this application. OSB not rated for direct contact with weather. You should put up a house wrap or tar paper, then install siding, then paint. There are some pretty inexpensive siding products out there that you could consider.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-09-2008, 08:34 PM   #3
I am sorry I should have said this is for the inside. I have tin on the outside.
Old 10-09-2008, 10:22 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
To get the best results, any bare wood should be primed with a good oil based primer, OSB included. Odds are your shed will not be climate controlled so I would use and exterior paint. A semi-gloss will give you more durability.
Old 10-10-2008, 12:34 AM   #5
DIY'er
jamiedolan's Avatar
Spend the $ on a quality primer and paint. Zinsser has several good primers. Sherwin makes great paints, but you won't like the prices if your thinking about Wmart paints. Walmart paints are hard to work with and don't cover well in many cases.
If you don't want to re-paint in a year or two, I would suggest you spend a few extra dollars on some good primer and paint. The quality matters. Some of the true value paints have produced excellent results for me. I used one of there poly paints for my work bench and it is really tough.
Jamie
Painting a wood garage door? sandyman720 Painting 8 03-31-2008 10:54 AM
Painting the inside side of Tar Paper; unfinished detached garage cityparkmark Building & Construction 8 03-03-2008 09:15 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
painting my garage floor (and some outdoor slabs) - are these any good? joeyboy Flooring 2 10-17-2007 08:13 PM
