Old 04-06-2007, 09:18 AM   #1
Painting New Plaster
We recently had two light coats of new plaster put on our living room ceiling. Does the new plaster job have to be painted? Thanks!
Bill45 is offline   Reply With Quote
Old 04-06-2007, 11:06 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Does it HAVE to be? No, I suppose not. I cant think of a functional reason that would require it to be painted. Sometimes even color is added to plaster to provide a final finish. Question is if you like the look. If you do, then leave it. If you are going to sell the house then paint it, most people would expect it to be painted. Don't not paint just because you are trying to avoid work.
Brik is offline   Reply With Quote
Old 04-06-2007, 01:03 PM   #3
Pro Painter
First, due to the porosity of plaster, it needs to dry for about 30 days before doing anything to it. If you want to paint then, use a good quality primer but NOT PVA primer.
If you don't want to paint, it will look good for quite a while but the walls will absorb moisture, gasses and stains from the natural activities inside the home. I would advise painting it.
joewho is offline   Reply With Quote
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Damp, Crumbling bricks & Blown Plaster crscrs Building & Construction 2 10-02-2008 06:20 PM
Plaster replacement lburele Building & Construction 1 04-29-2007 10:48 AM
Plaster removal decision Sarai Remodeling 2 09-08-2006 04:15 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
