Old 03-06-2013, 10:51 AM   #1
Painting New "Greenboard" Drywall
I have "green" drywall (mold/moisture resistant) I guees thats whats called greenboard in a basement bathroom. It doesn't seem to be as smooth as regular drywall. I am ready to start painting it. My questions are:
What kind of primer to use?
When should I caulk and what kind?
Should I sand it after priming?
Paint recomendations welcomed.
natspawpaw is offline   Reply With Quote
Old 03-06-2013, 10:58 AM   #2
I've never seen a rough finish on gree board.
Sure your not talking about where the seams where finshed?
They did not use the green board in any wet areas did they, like in the shower?
Where are you talking about caulking it?
Zinzeer 123 is what I use to prime with then two coat of paint.
Paint the ceiling first with a flat ceiling paint after priming.
Old 03-06-2013, 11:27 AM   #3
Its not "in" the shower, just above it, ceiling, and rest off the bathroom. It maybe not that rough just doesn't seem to be as smooth as regular drywall but it's all green. Seams appear to be fine.
Caulking between drywall and shower surround walls. (1/8" gap) Should I caulk before primer or after primer?
Old 03-06-2013, 11:29 AM   #4
Prime, caulk then paint.
Old 03-06-2013, 01:57 PM   #5
Super Moderator
Sanding----new work usually needs a quick sanding after the primer---this is to knock off any bit of dust and crud the is pulled off the face of the new work---
Very light--just to knock off any dust stuck in the primer.
Old 03-06-2013, 03:19 PM   #6
Gymschu's Avatar
Nothing special about painting Greenboard. Use the same materials and techniques you would use on regular sheetrock.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
oh'mike (03-06-2013)
Repairing old drywall inside corners before painting? Uncoiler Drywall & Plaster 7 07-08-2012 01:18 AM
Painting 'Bare' Drywall? ddawg16 Painting 11 06-02-2012 03:22 AM
drywall painting armsaround Drywall & Plaster 3 02-19-2012 05:37 PM
Painting new drywall Leanne1 Painting 12 02-05-2012 05:05 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
