-   -   Painting New "Greenboard" Drywall (http://www.diychatroom.com/f4/painting-new-greenboard-drywall-173722/)
natspawpaw 03-06-2013 10:51 AM
I have "green" drywall (mold/moisture resistant) I guees thats whats called greenboard in a basement bathroom. It doesn't seem to be as smooth as regular drywall. I am ready to start painting it. My questions are:
What kind of primer to use?
When should I caulk and what kind?
Should I sand it after priming?
Paint recomendations welcomed.
joecaption 03-06-2013 10:58 AM
I've never seen a rough finish on gree board.
Sure your not talking about where the seams where finshed?
They did not use the green board in any wet areas did they, like in the shower?
Where are you talking about caulking it?
Zinzeer 123 is what I use to prime with then two coat of paint.
Paint the ceiling first with a flat ceiling paint after priming.
natspawpaw 03-06-2013 11:27 AM
Its not "in" the shower, just above it, ceiling, and rest off the bathroom. It maybe not that rough just doesn't seem to be as smooth as regular drywall but it's all green. Seams appear to be fine.
Caulking between drywall and shower surround walls. (1/8" gap) Should I caulk before primer or after primer?
joecaption 03-06-2013 11:29 AM
Prime, caulk then paint.
oh'mike 03-06-2013 01:57 PM
Sanding----new work usually needs a quick sanding after the primer---this is to knock off any bit of dust and crud the is pulled off the face of the new work---
Very light--just to knock off any dust stuck in the primer.
Gymschu 03-06-2013 03:19 PM
Nothing special about painting Greenboard. Use the same materials and techniques you would use on regular sheetrock.
