Painting My Vanity - Painting - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 09:35 AM   #1
Painting my Vanity
Hi everyone!
I want to make my bathroom look more updated. It is very small & the vanity is golden oak. I can't afford to replace it right now, so I was thinking I might paint it or possibly stain it a dark cherry color or maybe black. Is that a bad idea or do you have any suggestions??? My woodwork is painted white so do you think that will clash or look ok? Will I have to sand the vanity before I stain it or can I just stain over top of it? Thank you!
IowaKate is offline   Reply With Quote
Old 01-22-2011, 01:41 PM   #2
Gymschu's Avatar
Rewards Points: 1,014
If the vanity is indeed oak, why paint it? How bout a light sanding & a fresh coat of polyurethane or a clear coat that was used originally. If it's really looking dingy, you're gonna have to sand, remove dust, prime with an oil-based bonding primer, sand again, and apply two coats of finish. That's a lot of work.....you may be well ahead to just buy the new vanity in my opinion.
Gymschu is online now   Reply With Quote
Old 01-22-2011, 06:25 PM   #3
Rewards Points: 252
if you want to stain it, the easiest thing to do might be a light sanding and coat it with a darker minwax polyshade color - you can't go lighter without a LOT more sanding... Polyshades is basically a colored poly.
If you want to paint, prime with a bonding primer - water based fresh start, aqua lock, 1-2-3 are all good - then top coat with a quality paint made for cabinets - cabinet coat, ben moore satin impervo, advance, all good.
Good luck
mazzonetv is offline   Reply With Quote
Painting laminate bathroom vanity perferd Painting 7 12-18-2010 09:48 AM
painting and glazing bathrrom vanity cougarguy Painting 2 02-03-2010 09:54 AM
HELP! Vanity tight squeeze 9728 Kitchen & Bath Remodeling 1 12-11-2009 02:53 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
