Painting Metal Stairs - Painting - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 03:14 AM   #1
Question
A while ago, I saw a DIY on TV that painted metal stair railings. Can you tell me what kind of paint that was? It was some kind of spray paint that had maybe some sort of fleck in it, I think. I'm told it will cost me $3,000 to redo my steps. YIKES! I think I'd rather at least try painting it for a new look. They've already been white and black, but need to have something done to them. Any suggestions? They are ALL metal interior stairs. When painting, what's the best way to cover the hardwood steps, etc?
ArlaFP is offline   Reply With Quote
Old 01-20-2011, 09:16 AM   #2
A Little Of Everything
Rewards Points: 1,362
I think Rustoleum carries a line of spray paints with all sorts of different finishes - hammered to metallic.
Your "make or break" on this project is going to be surface preparation. You'll need to get the old layers of paint off the metal - something that's going to be kind of tough and time consuming. You might want to try a heat gun and/or paint stripper. I've often used Aircraft paint stripper, but it's pretty aggressive stuff.
I think I'd also just paint the rails with a brush, using (possibly) Rustoleum oil-based enamel, instead of spray paint. It adheres well, and smooths out nicely. And no overspray floating through the house. Remember a good primer first.
I know of no way to protect your steps other than to mask well and cover them.
Good luck!
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
ArlaFP (01-20-2011)
Old 01-21-2011, 09:48 AM   #3
Rewards Points: 252
If you are planning on spray painting inside, just be careful to mask and cover everything ANYWHERE close that you don't want to get paint on. I'm not crazy about using spray paint inside but sometimes it is the only way to do something. Rustoleum does make a bunch of those hammered metal finishes which I'm sure you can look up on their website or in one of the larger paint stores / boxes near you. Also, just wanted to point out that removing ALL of the paint that is on the railing could be very messy and time consuming. The job could be done by simply wire brushing to get off whatever is loose / flaking / rusting etc.. Not necessary to go down to bare metal, but you do want to go down to a sound surface. So if there is paint that is adhering well you can leave that on - just make sure to prep it well enough so the edges are feathered if you go this route. Do you have any pics you can post?
good luck!
mazzonetv is offline   Reply With Quote
Old 01-21-2011, 10:24 AM   #4
Stairway painting
The paint that is there is sticking well. Just wearing off in places. I was just curious if the people who own this website knew what product was used on HGTV when they sprayed the staircase they did. Thanks for your replies.
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Painting a metal building. okinawap Painting 5 01-19-2011 11:43 PM
Painting over stairs Eusibius2 Painting 1 04-29-2010 11:18 PM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 11:31 PM
Painting Metal Stair Railings DanielleEglsNst Painting 8 10-08-2008 04:08 PM
