#1 |
Painting metal gutters
Hello all-
I'm getting ready to paint my house. I would like to do some minor gutter repair at the same time and paint them. I was curious to know if I should remove the entire gutter that runs the length of the house at the roof line or just paint it and not remove it first. I suppose just painting the downspouts would be all that is needed. Should I use a spray paint (brush prime first) or should I use just use brushes to do this? Thanks! |
#2 |
Tired, Cold, and Damp
Removing the entire gutter and spraying or brushing it will give you the best job, but depending on the condition of the trim, and the quality of job desired, painting them in place is acceptable
Often to properly coat the trim the gutters need to be removed, or at least moved, as they have not been removed to paint underneath during the last few paint jobs (sometimes for decades) and the paint on the trim underneath is in sad shape If the paint under the trim is in good shape, there's no reason not to paint the gutters in place, really |
#3 |
okay, cool. This is a repaint of the original paint job done about 8 years ago and the paint on the trim is in excellent condition. I think then by your advice I will simply leave them on. That is what I have been thinking all along, just wanted to double check with another person.
Thx |
#4 |
SeamlessGutterDelivery
Not sure if this is an option, but you may want to look into getting aluminum gutters and downspouts in the color that matches your trim. There are over 25 plus colors available. This would eliminate future painting of your gutters. Painted gutters/downspouts may crack and peal off.
#5 |
Just wanted to add that I removed and painted the gutters on my house with a hammered copper colored rustoleum spray paint I could only find at walmart.
It looks like copper gutters on the house. Neighbors walking by have commented on the expensive gutters We have and how great they look. I painted them about two years ago and they still look good. I don't have gutters on the whole house so it was a small project. Wanted to share. |
#6 | |
Painting metal guttersQuote:
Sounds like a great idea...... Pro Color |
| Display Modes | |
| Painting a metal building. | okinawap | Painting | 5 | 01-19-2011 11:43 PM |
| Wire size for 300watt trans, 3 way 100ft | Al the Diy guy | Electrical | 16 | 03-22-2008 09:46 PM |
| Painting metal flashing around chimney | abelsu | Painting | 3 | 05-17-2007 02:09 PM |
