Painting Metal Garage Door - Painting - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 01:10 PM   #1
Rewards Points: 99
painting metal garage door
Hello to all:
HOA forcing me to paint garage door and I was wondering the best way to go about it? I've had experience with indoor painting but not with outdoor. I figured the easiest way is to spray paint it but can't afford that route. If anyone with experience painting a metal garage door can send suggestions, I would really appreciated! thank you all in advance!!
er78mph is online now   Reply With Quote
Old 03-24-2013, 01:37 PM   #2
Rewards Points: 12,858
Clean it and use Sherwin Williams Super paint or Duration.
Last one I paint with it was 5 years ago and still looks like new.
Old 03-24-2013, 01:41 PM   #3
Rewards Points: 99
Did u use a reg roller and paint brushes??
Old 03-24-2013, 01:45 PM   #4
I like a 6" foam hot dog style roller and a sash brush for low areas and touch ups.
Old 03-24-2013, 10:06 PM   #5
I'm going to do my best joecaption impression
"got a picture"?
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (03-25-2013)
Old 03-25-2013, 08:41 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
"got a picture"?
Old 03-25-2013, 09:29 AM   #7
Gymschu's Avatar
Rewards Points: 232
Never had much luck with the FOAM hotdog rollers........they just don't hold enough paint. Might be better to try a 6" Wizz roller.......holds much more paint and will give you the same type of finish.
Gymschu is online now   Reply With Quote
Old 03-25-2013, 11:46 AM   #8
cdaniels's Avatar
The Whiz rollers do pretty good on metal doors.Roll it out smooth there will be a little roller stipple but it lays down pretty good.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-25-2013, 06:04 PM   #9
I used a foam roller for about three minutes, once.
Old 03-25-2013, 06:15 PM   #10
All I've ever used on steel and wood doors and trim. Comes out looking like it was spray painted when done.
Old 03-25-2013, 06:20 PM   #11
Gymschu's Avatar
Rewards Points: 232
Joe, how do you get paint on those darn things? I agree that they produce a sprayed on look but I can never get them to hold much paint. I have to keep dipping and redipping just to get some paint on the darn things.
Old 03-25-2013, 10:40 PM   #12
Rewards Points: 148
i used a foam roller on a steel door. turned out pretty good. no issues with it holding paint.
Fix'n it is online now   Reply With Quote
Old 03-26-2013, 08:33 AM   #13
chrisn's Avatar
Rewards Points: 136
two minutes more than me
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (03-26-2013)
Old 03-26-2013, 08:34 AM   #14
chrisn's Avatar
Rewards Points: 136
got a pic?
Old 03-26-2013, 05:27 PM   #15
Rubbin walls since'79
Brushjockey's Avatar
Oh snap!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Garage door removal bmorekid Carpentry 2 12-31-2011 11:18 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
