Painting Metal Front Door - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 03:29 PM   #1
Deck Staining Pro
bigchaz's Avatar
Painting metal front door
Hi everyone, thanks as always in advance for all your help.
I have a newer metal front door (primed white from the factory) but never painted. There is no rust. I painted the inside of the door very carefully with brush and it came out pretty smooth (using SW pro classic which levels very nicely).
On the outside of the door I'm using a teal color and SW Resilience exterior latex. Brush marks are a little more obvious on the outside. What would be the best way to apply the second coat to try and create a smoother appearance?
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Old 02-05-2013, 04:03 PM   #2
Rewards Points: 708
I've never tried it but I've read that with some paints a sponge roller used in conjunction with several coats of really thinned paint gives excellent results. Of course that would only work best on smooth flat surfaces. A spray gun would probably be the very best or take it to an auto body shop but that wouldn't be a DIY job.
Old 02-05-2013, 08:09 PM   #3
cdaniels's Avatar
What kind of brush are you using? Your not going to be able to brush a door without leaving SOME brush marks. Sand after the first coat with 220, get you a good brush( I use a 3 in. Purdy xl sprig) Thin just a little if you need to and lay it off as smooth as you can.Latex is harder to use because it dries so much faster.You really have to move along at a pretty good pace to keep it from lapping.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-05-2013, 10:26 PM   #4
Rewards Points: 13,296
A foam roller will make it come out like glass.
Old 02-05-2013, 11:23 PM   #5
Deck Staining Pro
bigchaz's Avatar
I'm using a Purdy XL 3" brush. I may try to foam roller for the flat areas, the tricky part was doing the 6 boxes that are recessed a little for design.
Would it help to thin the paint some for my second or third coats?
Charlie Soden
Apex DeckSavers
Old 02-05-2013, 11:34 PM   #6
cdaniels's Avatar
Yes....it would help but just enough that it flows well.I personally have never rolled a door so I don't know how it will turn out.I have rolled them and brushed them out,but never let a rolled finish on a door.Good luck.
Old 02-06-2013, 08:04 AM   #7
I used SW Resilience, once.
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (02-06-2013)
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
louvered metal door to replace louvered wooden door norfolkgarden HVAC 5 12-19-2010 05:09 PM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
