Painting Mess In My Bathroom - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 06:45 PM   #16
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Originally Posted by slt View Post
Thank you so much Kevin, one more question if you don't mind... do we apply primer to the ceiling before we texture, after or not at all. Originally, there was none on the texture, but I would guess the sheetrock was primered first. Just want to do this very very right.
Many thanks,
Susan
Susan,
It's OK to be thorough in your fact finding on your project. Eventually all of the pieces of the puzzle fit together.
If you removed any loose paint or loose texture from your ceiling, vacuumed it off and wiped with a damp sponge, the new texture will adhere with no problems. If you dug into the Sheetrock and exposed the brown paper core, you need to seal it with an oil primer before you texture.
You don't need to prime or paint the new texture. The majority of new home construction, at least in my area, apply the texture as a finish coat to the ceiling and let it go at that.
You can paint it if you desire, just make sure you use a quality paint, as opposed to the labeled discount ceiling paint.
Kevin
Kevin M. is offline   Reply With Quote
Bathroom ceiling painting not-real-handy Painting 5 08-23-2009 06:30 PM
painting joint compound in a bathroom AnnaVanLenten Painting 5 10-09-2008 11:14 AM
painting bathroom - primer for greenboard and hardiebacker? carrotguy Remodeling 5 06-23-2008 03:50 PM
Painting bathroom with lots of moisture? DK75 Painting 2 02-08-2006 01:08 PM
