Painting A Linoleum Floor - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 10:45 AM   #1
painting a linoleum floor
I have a 30 year old kitchen floor covered with linoleum that has been gouged, dented and discolored from heavy use. I would prefer to avoid the cost of applying a new floor covering at this time but I would like to clean it up a bit. What do you think about covering it with a satin finish latex floor paint? Thanks for your comments!
minchu is offline   Reply With Quote
Old 01-31-2009, 11:34 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,714
Ayuh,...
Any imperfections that can be seen Now, will be More visable after it's painted....
It might look Ok for a short time, but it Won't last very long...
Old 01-31-2009, 05:40 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Time for new flooring
There are precious few coatings that even have a chance (and a very small "maybe" chance at that) of sticking to actual linoleum
And, as mentioned, even if it sticks (again, very unlikely), "paint colors, it doesn't fill"
And the nice semi-shiny satin finish of most "Porch And Floor" type enamels would actually accentuate any gouges and dents
And in addition, if (pretty much "when") it fails, it really makes a huge, huge, mess that requires a boatload more work to fix
Sorry
slickshift is offline   Reply With Quote
Old 02-02-2009, 06:36 AM   #4
ccarlisle's Avatar
Even if you are lucky enough to find a paint that will stick to linoleum, one you put it down and then apply pressure to it (like walking on it) the layer of paint on top will flex with the softer linoluemn underneath, and crack.
Not a pretty sight...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-02-2009, 06:43 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Let alone the YEARS of wax buildup that would HAVE to be removed first!
Old 02-05-2009, 03:27 PM   #6
Painting an linoleum floor!
Thanks for the input! It was wishful thinking, of course. I just wanted to avoid the expense! Thanks to all.
Old 02-06-2009, 10:23 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
It's really not that hard of a job to replace a floor and you will be much happier that you did.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
painting my floor Eli Flooring 3 03-20-2011 04:11 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
