Painting A Laundry Room - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 11:53 PM   #1
Rewards Points: 53
Painting a laundry room
I'd like to re paint my laundry room. Do I need to use any special paint because of potential moisture from the washer / dryer?
I have a gallon of Clark and Kensington latex paint. Can I put that straight on or should I use zinger 123 to prime it with mold resistant?
majch is offline   Reply With Quote
Old 07-18-2012, 12:25 AM   #2
Rewards Points: 13,270
May want to just add a pac of M-1 sold at Home Depot or most hardware stores. It's a midicide.
Unless the walls are in bad shape and need repairs, it's bare sheetrock , or your drasticly changing the color no need to prime.
Old 07-18-2012, 04:42 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Is the dryer not vented? How much moisture escapes the washer?
Old 07-18-2012, 09:15 AM   #4
Rewards Points: 53
Hi - The dryer is vented. Both appliances have been bought within the last 2 years, so they are newer. I don't feel like the laundry room is humid, but not sure about right way to paint it.
Old 07-18-2012, 10:12 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
I think a quality eggshell finish and you are fine. It will have a fair amount of moisture resistance and also be able to be wiped because laundry rooms see some action.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-18-2012, 10:27 AM   #6
Rewards Points: 53
Should I prime with it something that is moisture resistancent or am I good to go? There's existing paint on there and there's not a lot of color descrepancy to warrant a prime outside the potential of moisture.
Old 07-18-2012, 10:49 AM   #7
Rewards Points: 278
I can't see a reason at all to use it with a MR paint....UNLESS you have issues with your ducting, in which case - fix that
mobiledynamics is offline   Reply With Quote
Old 07-18-2012, 12:37 PM   #8
You haven't really said you presently have a moisture problem, so you should be fine.
Old 07-18-2012, 03:05 PM   #9
Phil - "the Paint Guy"
The surface to be painted must be clean, dull and dry in order for another. Coating to adhere to it. Most laundry rooms do not require any special m.r. paint. If the existing paint is in good condition then prep it and repaint using a high quality semi gloss or gloss or latex paint Remember the higher the paint sheen the more resistant to moisture it will be. Otherwise an eggshell sheen would work as well.
Cpcphil is offline   Reply With Quote
Old 07-18-2012, 03:46 PM   #10
Rewards Points: 53
Excellent ! Thanks to everyone for sharing their expertise.
Old 07-18-2012, 05:35 PM   #11
chrisn's Avatar
Rewards Points: 228
eggshell is all you need
Basement laundry room secutanudu Electrical 9 04-23-2010 04:23 PM
Laundry room remodel RegeSullivan Remodeling 3 02-08-2010 04:56 PM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 10:19 AM
Laundry Room and half bath overhaul! gone_fishing Project Showcase 10 04-29-2008 08:08 PM
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-22-2007 12:12 AM
