Old 03-26-2012, 02:45 PM   #1
Painting latex primer over wood trim
What is the worst that could happen if I paint a latex primer over existing wood trim that has been sanded ?
Mumsie is offline   Reply With Quote
Old 03-26-2012, 02:47 PM   #2
How else would you do it?
Old 03-26-2012, 05:01 PM   #3
paper hanger and painter
chrisn's Avatar
huh??
Old 03-26-2012, 05:09 PM   #4
ltd
ltd is offline   Reply With Quote
Old 03-27-2012, 10:33 AM   #5
Gymschu's Avatar
Well, if you don't vacuum up the sanding dust there is a possibility that the primer won't adhere properly & give you an unsound surface for your finish coats.
Old 03-27-2012, 12:27 PM   #6
Mr. Paint's Avatar
You don't provide much information. If you have new, patched sanded and wiped wood, use a good Latex Enamel Undercoat. If you have previously painted, cleaned, sanded and wiped wood, a good adhesion-promoting primer would be sufficient.
Mr. Paint is offline   Reply With Quote
Wood Trim - Spraying Latex on Oil Twister Painting 10 12-11-2011 03:18 PM
oops Used latex primer lvirtue Painting 3 12-08-2011 06:23 PM
Painting pine - primer? marliz Painting 17 12-12-2010 08:37 PM
Painting wood finished trim white... leverne99 Painting 12 06-06-2009 07:31 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 03:57 AM
