-   -   Painting latex primer over wood trim (http://www.diychatroom.com/f4/painting-latex-primer-over-wood-trim-138328/)
Mumsie 03-26-2012 01:45 PM
What is the worst that could happen if I paint a latex primer over existing wood trim that has been sanded ?
joecaption 03-26-2012 01:47 PM
How else would you do it?
chrisn 03-26-2012 04:01 PM
huh??:huh::huh::huh:
ltd 03-26-2012 04:09 PM
Gymschu 03-27-2012 09:33 AM
Well, if you don't vacuum up the sanding dust there is a possibility that the primer won't adhere properly & give you an unsound surface for your finish coats.
Mr. Paint 03-27-2012 11:27 AM
You don't provide much information. If you have new, patched sanded and wiped wood, use a good Latex Enamel Undercoat. If you have previously painted, cleaned, sanded and wiped wood, a good adhesion-promoting primer would be sufficient.
