Painting Latex Over Oil Based Paint - Painting - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 03:49 PM   #1
painting latex over oil based paint
I am painting latex over oil based paint that has also been feather dusted! I used Behr paint and primer after washing and sanding the walls - I have had no issues but I only did one room and now I have the rest of the house to do 2500 sq ft - should I be using oil based primer first?
macoretta is offline   Reply With Quote
Old 07-15-2012, 04:24 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
Unless you are really sanding very well, a good bonding primer is required, not necessarily oil but Zinnser's Cover Stain would be a good one, Bullseye 123 or Fresh Start would work as well
Old 07-15-2012, 05:40 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
The walls are in oil? How do you know?
And I've never had "feather dusted" in my prep list! lol
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-16-2012, 03:41 AM   #4
chrisn's Avatar
Rewards Points: 312
You noticed my restraint on his paint choice?
Old 07-16-2012, 08:38 AM   #5
Definitely use an adhesion primer. It would be the rare person that would actually sand an oil finish well enough to back over it with just a latex top coat, and if you really read the data for those paint and primer in one products, they sure recommend primer in a lot of situations.
Todays acrylics have a lot better adhesion than those from the past, but a good primer will save you from a lot of future headaches. What looks good today may start quickly peeling off with actual living.
Xoch is offline   Reply With Quote
Old 07-16-2012, 07:45 PM   #6
Yup, you awesome in your subtility! ( I just made that up!)
Old 07-17-2012, 04:07 AM   #7
chrisn's Avatar
Rewards Points: 312
I will accept that
PreVal Sprayer: Anybody Tried It With Latex? Twister Painting 7 10-17-2013 12:36 AM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Interior oil based paint then latex exterior katiegr Painting 3 06-08-2012 03:23 AM
Painting Bookshelves - what type of paint? justin2009 Painting 9 01-05-2009 09:18 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
