Painting Lamp/Lantern - Painting - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 12:29 PM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
This is my current project.
Apparently the previous owner had painted it black, and the black paint was bubbling/peeling. I had some chemical stripper in the garage so I used it to remove most of the black paint. Underneath it looks like a copper plated metal. Unfortunately the copper plating is in bad condition so I'd like to repaint it black.
Any suggestions on primers, paints, or procedures would be appreciated.
Painting Lamp/Lantern-100_1071.jpg
Old 03-08-2012, 12:40 PM   #2
Mr. Paint's Avatar
I recommend an alkyd (Oil-base) brush-on primer, it should be a red oxide color. Spray-on primers generally dry too fast and end up too thin to give good performance. If you go back to black, consider using a high-heat product. These are sold as BBQ black. They have a better tolerance of heat on a metal surface. A spray can of this should work fine. Use Two or three coats allowing recommended dry time.
Have fun!
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
Blondesense (03-08-2012)
Old 03-10-2012, 02:45 AM   #3
Too Short? Cut it Again!
Have fun!
Agree to a point but if you do not like black, look for high heat products like engine enamels at your auto parts store, or online. Not sure I understand the red oxide primer but you definitely need a good metal primer so why not. I agree to use a brush on primer and you can get rust inhibiting or even rust converting one (ask a Navy maintenance person for current hot brands).
You probably need to prep the surface of what you have better than you have. I am lazy so would probably take it to a metal person or anybody with a sandblaster and fine grit. In the old days before I was lazy, I would have take fine wet sandpaper to it before priming and painting. It looks like it could be nice. Do not skimp on the prep.
Old 03-10-2012, 04:13 AM   #4
Stuck in the 70's
Thanks. I know there is more prep work to be done. I should have specified this was just round one - started on one of those rare, nice afternoons off where you look for something that calls to be done outside.
Old 03-10-2012, 04:44 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
[quote=Blondesense;874542]Thanks. I know there is more prep work to be done. I should have specified this was just round one - started on one of those rare, nice afternoons off where you look for something that calls to be done outside.[/quote]
You have to look?
Old 03-10-2012, 01:16 PM   #6
Stuck in the 70's
Originally Posted by chrisn View Post
You have to look?
Too true!
Also a plus if the job entails a lot of sit-down-and-wait-with-your-favorite-beverage time.
Old 03-11-2012, 12:42 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Blondesense (03-11-2012)
Old 03-11-2012, 06:33 AM   #8
I just did one of these last fall. I washed it, wirebrushed/sanded the flaking paint, then dusted it off. The one I did, looks identical, dismantles to three or four pieces. I did it in tricolor. Silver and black, and the eagle appropriately in gold. I used Rustoleum spray products, no primer. I don't see the need for primer, and think it's a bit overkill. And I wouldn't want brush marks on it. Red oxide is a ferrous metal primer, copper plate is not ferrous. But, it never hurts to prime and RO carries a variety of them is spray if you choose. I slip a plastic bag over my arm as a spray sleeve, or you could use a long rubber glove, to hold the pieces when you spray. READ the label and adhere religiously to spray/recoat times. Spray paint will fail if you rush and recoat too late or too soon, and you'll have a wrinkled finish. When you read the label you'll understand. I'll try to post a pic sometime today.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 06-18-2012, 12:33 PM   #9
Stuck in the 70's
I'm a little slow, but it's finally done.
Thanks for the help.
The sad thing is I was wrong. It wasn't copper plated, it was solid copper.
I would have loved to clean it up and let it patina naturally, but I may as well have hung a sign that said "steal me".
Painting Lamp/Lantern-afterlight.jpg
Old 06-18-2012, 01:51 PM   #10
They are just finishing a weird but nice massive restoration on an old Catholic church near me. It is one of those deals where they sort of wrapped a new highrise around it. Looks goofy to me but I am sure it was historically landmarked or something.
Anyhow, the massive, ornate roof and all the gutters and dounspouts are copper. I half expect to walk past it and see that some have removed the whole roof overnight! I am sure they will get at the downspouts if not the gutters.
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
