Painting Laminate? - Painting - DIY Chatroom Home Improvement Forum
Old 08-24-2008, 08:57 PM   #1
painting laminate?
Only my 2nd post on the forum so go easy on me please!
I have a small TV stand that I purchased from Best Buy several years ago.
It is pretty solid, seems to be made of solid wood, but laminate covers the whole stand. It has a few small scratches etc. on it but other than that it looks ok, with the exception of the color, which is a dull gray.
My question is, can I paint it? Is it gonna look like crap afterwards? If so, is there a particular type of paint I should use? Or should I attempt to replace the existing laminate with something new and better looking?
Any suggestions or advice will be greatly appreciated!
Thanks!
melaluca02 is offline   Reply With Quote
Old 08-24-2008, 09:47 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
You should be able to clean, scuff sand, prime (solvent-based primer), and paint
I'd suggest an enamel (waterborne or alkyd "trim" paint) for the paint
slickshift is offline   Reply With Quote
Old 08-24-2008, 09:54 PM   #3
Rewards Points: 2,906
prolly
prolly
Is there a particular type of paint I should use?
Laminate is made of a pretty hard plastic to stand up well as a shelf or working surface. Go to your local hardware store or home center and look for Norton "3X" Premium aluminum oxide, which is a sandpaper that's 3 times as sharp, 3 times as hard and lasts 3 times as long. Get 220 grit or so. Sand down your laminate to get a dull surface on it, clean up the dust, and apply an INTERIOR ALKYD primer. Then apply any interior alkyd paint tinted to the colour you want over that.
That laminate may be glued to "processed" wood like particle board or MDF, and you might end up pulling chunks of particle board or MDF out when removing the laminate. I'd paint it first, and only opt for relaminating as a last resort. Do you have a router or laminate trimmer? You will need these tools to do a decent job.
If you don't like the paint job, then use a heat gun (or a chemical paint stripper) to remove the paint, and then take a shot at relaminating. I doubt that paint stripper would harm laminate.
Nestor_Kelebay is offline   Reply With Quote
Old 08-25-2008, 06:33 AM   #4
slickshift's Avatar
Laminate is also made of wood
Laminate can also be that "wood product" which is basically a picture of wood (paper) glued to fiberboard
I assumed it was wood laminate
Nester assumed plastic
Perhaps we should ask the OP for a clarification
Old 09-06-2008, 05:12 PM   #5
Originally Posted by Nestor_Kelebay View Post
prolly
prolly
I like this particular advice, I will be attempting this in the near future.
I definitely think painting it will be my best bet. I don't have a router or laminate trimmer. Sandin, priming, painting seems to be a much easier route and I'm sure it'll look great when I finish. I will post when done, and include before/after pics.
Thanks so much for the advice!
Old 09-06-2008, 05:13 PM   #6
I do believe it is a wood laminate.
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 06:05 PM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 02:24 AM
