Painting Knotty Pine ?? - Painting - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 11:20 AM   #1
Rewards Points: 91
painting knotty pine ??
i am close to painting on my addition, I will be painting my ceilings that are constructed out of 1x8 v groove wood. it is a pine product with knots. what is the process and materials for priming and paint so the knots won't bleed thru? I was told to shellac over the knots?
gwilkrrs is offline   Reply With Quote
Old 10-09-2013, 11:28 AM   #2
Rewards Points: 4,796
A shellac-based primer would work well over wood with knots. BIN is a very common one.
Other than shellac, the general rule of thumb is "oil blocks water, water blocks oil". In other words, use a water based primer to cover oily, greasy stains. Use an oil-based primer to cover water stains. Wood tannins are water based, and therefore should be covered with an oil-based primer, if not using shellac.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
ddawg16 (10-09-2013)
Old 10-09-2013, 11:32 AM   #3
Rewards Points: 105
You can also fill th knots with wood putty or something like mh ready patch.
r1racer is offline   Reply With Quote
Old 10-09-2013, 12:46 PM   #4
Painting Contractor CT
Rewards Points: 77
Post
You could also apply oil-based primer and that should prevent bleeding. Good Luck!
KD PAINTING is offline   Reply With Quote
Old 10-09-2013, 02:24 PM   #5
Rewards Points: 91
thanks. I will just use an all surface oil based primer then.
the knots are surface not actual holes..... I didn't want the extra steps of shellac
Old 10-09-2013, 02:49 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
Why not stain?
I personally think knotty pine looks very good stained....especially inside....a bit more work...but looks good.
And is pretty much ageless.....
Exception being...if the general look of the room is no where near country or something similar...then paint.
The Following User Says Thank You to ddawg16 For This Useful Post:
ToolSeeker (10-10-2013)
Old 10-09-2013, 04:03 PM   #7
The shellac isn't an "extra step". You would simply use BIN as your primer instead of an oil based primer.
The Following 2 Users Say Thank You to jeffnc For This Useful Post:
gwilkrrs (10-09-2013), Gymschu (10-09-2013)
Old 10-09-2013, 06:16 PM   #8
Rewards Points: 91
it isn't being stained because the boss said "no". I thought we were but nope.
I misread the BIN comment, my bad, I thought it was BIN and then primer.......
Old 10-09-2013, 07:47 PM   #9
Jmayspaint's Avatar
Rewards Points: 536
You will have better luck with blocking the knots with shellac than oil. Oil primers like Cover Stain are the go-to for tannin bleed (knots), but I have been seeing failure with oil primers alone.
Spotting with shellac, then a full oil prime is a safer bet. But even that doesn't always hold long term with new wood.
I have been hearing that ext wood glue spread over the knots works well.
Jmayspaint is online now   Reply With Quote
Old 10-10-2013, 08:51 AM   #10
Rewards Points: 6,034
Another beautiful ceiling bites the dust. You could probably remove the wood sell it for enough to buy drywall. I know I would buy 1x8 t&g knotty pine.
Old 10-10-2013, 07:57 PM   #11
Rewards Points: 91
another ceiling didn't bite the dust- one was just created. they are 13 foot tall cathedrals with exposed ridge beam and fake rafters at 4' o.c.
Old 10-11-2013, 10:27 PM   #12
Matthewt1970's Avatar
Rewards Points: 1,098
This. When it comes to knots I have found latex primers block the tannins for a few days, oil based primer block the tannins for a few years, and shellac block the tannins for a few decades.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-12-2013, 06:08 PM   #13
Rewards Points: 91
wow- sprayed the ceiling with bin today- that stuff is like water!! I sprayed all 1 ceiling instead of spot priming the knots I just did all of it- need to get more for the other ceiling............ thanks everyone
How well does solid (opaque) stain cover knotty pine? skidoo42 Painting 5 11-26-2012 09:53 AM
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 09:25 AM
Painting pine - primer? marliz Painting 17 12-12-2010 07:37 PM
Knotty Pine mgortel Carpentry 5 06-21-2010 08:21 PM
HELP!!! Primed Knotty pine... needs to be unprimed! deke44 Painting 2 06-04-2010 03:44 AM
