-   -   Painting kitchen cabinets, Wagner HVLP conversion gun? (http://www.diychatroom.com/f4/painting-kitchen-cabinets-wagner-hvlp-conversion-gun-102523/)
Cobrakillert 04-23-2011 09:25 PM
I'm just about ready to tear into my kitchen for it's makeover. My doors, drawer fronts, drawer boxes and hardware from Barker Door are all here an all I need to do is finalize color/product and the exact method of painting the cabinets.
You can see my original thread on the kitchen HERE
After looking around at inexpensive HVLP systems I came across the Wagner HVLP conversion gun. It seems to get better result than the cheaper HVLP systems (HF, Rockler, etc.) and being that I already have a Craftsman 2HP 33 gal. compressor which puts out 8.6CFM @ 40 PSI it seems like this is a good option and the better way to go. Am I correct that going with the Wagner HVLP conversion gun is the better route vs the inexpensive HVLP systems at the same pricepoint?
If I go with the Wagner, would a pressure pot be needed to spray the cabinet boxes while they are still mounted on the wall?
Any insight on settings for the gun/compressor?
As far as the process...I'll go with the BM Satin Impervo paint, what would be my best choice for a primer? Should I sand between primer and paint? How 'bout between the first and second coats of paint?
What should I do to the darker stained cabinets to prep them before spraying on the primer?
This will be the first time I'll be using a sprayer and I'm just a beginner painter but have no hesitation on taking on larger tasks like this, any insight/instruction would be GREATLY appreciated!
Cobrakillert 04-26-2011 05:01 PM
Anyone have any advice for a newbie before I go ahead and order this HVLP conversion gun?
Millertyme 04-26-2011 07:21 PM
test the gun out on a practice piece and play with the settings. Find what works the best. Ive never used the gun you are talking about but I have used the hvlp guns quite a bit with good success. Make sure to use a good primer before you start, No need to sand in between unless there are any defects or if you want it smoother.
Cobrakillert 04-27-2011 06:41 AM
Thanks for the reply...
I'll be leaving the cabinets mounted and the doors I'll paint in my garage. As a first time sprayer, will an HVLP gun be easy enough to use or am I better off just going with a brush and roller?
Gymschu 04-27-2011 06:47 AM
When in doubt, do not spray! Add in the time for prep and clean up and you basically don't save a whole lot of time. Just my opinion.
Ed G 04-27-2011 07:00 AM
As said before, the key here is to practice, practice and practice. Either brush/roll or spraying will work, but you have to have your technique down first. I don't think I would spray oil indoors, even in the garage- the overspray will stick to everything in sight. When I spray, I typically wait for a nice cloudy day (plenty of those here in NE Ohio), spray in the yard and quickly take the pieces into the garage to dry. When you do the doors, paint and dry them horizontally to help the paint level and avoid runs. Good luck!
Cobrakillert 04-27-2011 08:28 AM
I'm not really worried about time, I'm more focused on the end result. I want to get the best finish as possible.
As far as product, how is the BM 'Advance' line? It seems to be an 'oil-based' with soap and water clean-up. What would be the best primer to use? BM 'Advance' primer as well?
Thanks for the tip on spraying the doors horizontally, I had already planned on doing that as well as painting the back of the doors first and then the fronts.
user1007 04-27-2011 08:37 AM
I would think twice about spraying them. And if you must or just really want to do so. Don't buy a Wagner toy. You will be disappointed. Rent decent spray equipment.
Cobrakillert 04-27-2011 10:34 AM
Could you elaborate on why I should think twice about spraying them?
Also, I've read very good reviews on the Wagner HVLP conversion gun, why do you say that I will be disappointed?
user1007 04-27-2011 10:54 AM
The Wagner sprayer will probably get you through this project and I suppose a few others but the price point is achieved with a lot of cast (not machined) and plastic parts that can fail. I have known too many people that have had to take a couple back to get one that was working. This was the case for the last client of mine that really, really wanted to own one for reasons I never quite figured out. Garage ornamentation I guess.
Personal bias I suppose but I would feel more confident with rented professional spray equipment---machined metal parts and all that. Through my career I had so little use for a sprayer that it made no sense to own one. I either rented or more often brought in the sub-contractors with the equipment on larger jobs suited to spraying. Few of mine ever were.
As for reconsidering spraying? Just remember you are going to have to make several passes to achieve the paint film thickness you want for cabinet doors. I think you might find rolling two coats on to be faster in the long run with the same or better results. And less of a mess from overspray and so forth.
Just food for thought. It sounds like you are putting the thought and prep into this that your project will turn out well either way.
As for paint? I would use a high acrylic waterbased semi gloss if it were me. Add Floetrol whether spraying, brushing or rolling for a near brushstroke free finish. For primer? Depending on what is on the doors now I guess you could use a high quality bonding latex primer. I would use an alkyd though.
kennyb 05-04-2011 06:53 AM
To spray or not to spray!
There is no reason not to use the conversion HVLP gun.That is not on the same level as the other WAGNER consumer items.The conversion gun is probably the best thing on the consumer market from Wagner.I have 20 plus years experence with using most all spray guns.(professional and consumer)The best advice for you is to practice allot and when using HVLPs always remember the less air you use the less overspray you have!You will have to to be closer to the surface and use slower passes with the gun.It is possible to spray with little to NO overspray.When your spray gun is dialed in right it will give you the end result that will amaze you.:thumbsup:
jjrbus 03-24-2013 04:15 AM
I have some projects I would like to spray, mostly small, not the whole house, not that it makes any sense time wise, I just want to spray them. I have almost no spray experience.
To rent a quality sprayer as suggested, I would not be able to develop any technique or spend much time practicing. I am not going to rent a quality sprayer to paint a couple cheap lawn chairs just to practice on!
So I started poking around the web and found this Wagner conversion gun.
Wagner Power Products 276124 Conversion Gun
I find no other opinions on it here on the forum since 2011 and am hoping some have bought and tried it and are willing to share their experience with it!
Thanks JIm
jagans 03-24-2013 05:57 AM
I have this gun and I like it, Mine is all metal parts, except the check valves which are replaceable, so Im not sure what the guy that knocks them is talking about. I bought mine a long time ago from Gleem, so maybe they have been cheapened up? Who knows.
I would not spray in the house. I am about to do the exact same project, but I am going to brush the stiles inside, and spray the doors and drawer fronts on a rack which I will build in the garage. Spraying inside a finished house is asking for trouble, and the stiles and sides are not much area. I am going to clean the cabinets with TSP then prime with a good primer. then spray several light coats, probably semi-gloss. I will clean out and wet down the garage floor to help with the dust, which is always a problem when spraying anything.
You don't need a paint pot, the Wagner cup holds plenty for this job.
If you are not experienced with spray, you better practice.
Thats what I am going to do. Not to Hijack, but primer/paint recommendations are welcome by me I have an SW store nearby, and can get any other finish I'm sure.
ToolSeeker 03-24-2013 07:18 AM
This is an old post but let me put my $.02 in Wagner got a pretty bad rep from the old yellow buzz sprayers. And I think some are confusing these with the conversion gun. A lot of painters on this site don't like spraying and I can understand that. After years of brush and roller the first time I sprayed it was an interior and it looked like the fog had rolled in. When I came outside you could see around my eyes where my glasses were because that was about the only part that wasn't painted. I HATED IT. I put the sprayer in the garage for almost 2 years then I hired a guy and we were doing a large job and he said we needed a sprayer I told him I had one. Then when he finally settled down I found out he had experience with a sprayer. After a few lessons the sprayer is now a large part of my paint arsenal.
jjrbus 03-24-2013 08:53 PM
I have not used an airless sprayer in decades, but cannot understand why many would not use them?
In the intervening years I have used a cheapy Wagner, real piece of c--P
I have read many good things on this conversion and may just give it a try. Nothing beats a spray finish on some things!
I have yet to see an amateur cabinet or furniture paint job that looks good! Even mine!
JIm
