Old 07-09-2011, 11:31 AM   #1
Painting kitchen cabinets?
I admit, I am not the most experienced handy-girl, but I want to take my '77 kitchen cabinets from dark stained wood to white. I have a sander, but am wondering if I actually need to sand every little piece, or if I can just start painting. Any good news for me?
wmdcookes is offline   Reply With Quote
Old 07-09-2011, 11:56 AM   #2
Framing Contractor
Do a lot of research on this. It is very difficult to paint cabinets and have them end up looking really nice.
sixeightten is offline   Reply With Quote
Old 07-09-2011, 01:05 PM   #3
There's a new product on the market by Rustoleum for painting kitchen cabinets and counters. It sounds easy. I have not used it. Just saw it in Lowes. You might look into it.
JoanBologna is offline   Reply With Quote
Old 07-09-2011, 01:48 PM   #4
I painted my dark wood kitchen cabinets a year ago, and used STIX acrylic bonding primer. It is really good stuff. Even drips on a not too clean kitchen stove were hard to get off. However I did do a light sanding with fine grit paper to rough up the glossy finish that was on the wood.
BTW, I used high gloss paint for the final (2) coats, and tapped lightly over each coat with a grout sponge just before it dried. Removed all drips and brush strokes. It turned out well, still glossy but a uniform texture, hiding any flaws.
NancyNGA is offline   Reply With Quote
Old 07-09-2011, 01:57 PM   #5
Workaholic's Avatar
First step will be to fill in all the old holes that will not work with new hardware then you will want to thoroughly sand and then prime with an oil primer then sand again, in between sanding you should wipe with a tack cloth, after this is done then you can get to two coats of topcoat, I recommend spraying through this process but I understand that not everyone will be able to do this.
I recently used the rustoleum product and posted pics of the results in this thread.
Need advice on refinishing my kitchen
Sean
Workaholic is offline   Reply With Quote
Refacing kitchen cabinets without any veneer? loft_lover Carpentry 1 11-18-2010 07:23 AM
Painting Kitchen Cabinets. Do I need a clear topcoat? tigereye Painting 1 11-23-2009 03:35 PM
Painting white kitchen cabinets bonbroc Painting 1 09-25-2009 11:53 AM
Painting kitchen cabinets buckwillis Painting 7 08-23-2008 09:42 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 14 07-21-2008 12:32 AM
