Painting Iron Railings - Painting - DIY Chatroom Home Improvement Forum
Old 04-12-2014, 10:09 AM   #1
Rewards Points: 101
Looking for some suggestions on primer and/or paint for exterior iron railings. Last spring I used Rustoleum but this spring I have quite a bit of rust and flaking spots. I plan on stripping and cleaning it up with a wire wheel attachment on my drill.
Was just wondering what a good paint an primer would be? Thanks
jte1130 is offline   Reply With Quote
Old 04-12-2014, 12:22 PM   #2
Rewards Points: 12,830
Remove all the old loose paint and rust.
Apply a product called Rust stripper. http://www.rustoleum.com/product-cat.../rust-stripper
Rusty metal primer, then a finish coat of paint.
Jmayspaint (04-12-2014)
Old 04-13-2014, 07:53 AM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Remove all loose, peeling, chipping paint and rust. Clean surfaces to be painted, prime using Sherwin Williams Kem Bond HS primer and then paint using a DTM (direct to metal) such as Sherwin Williams DTM.
housepaintingny is offline   Reply With Quote
Old 04-13-2014, 11:09 AM   #4
Rewards Points: 4,780
You'll wear yourself out with a drill. Use a grinder and wire wheel instead. If you don't have one, you can buy them cheaply at Harbor Freight.
http://www.harborfreight.com/4-12-an...der-60625.html
http://www.harborfreight.com/4-1-2-h...eel-91282.html
Please be careful.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
jte1130 (05-17-2014)
Old 05-17-2014, 07:12 PM   #5
Rewards Points: 101
Picked up the angle grinder from Harbor Freight today. Worked great!! Did one side in about 20 minutes. Can't go wrong for $14 bucks. I think Harbor is my new favorite store. Thanks for the recommendation.
Old 05-17-2014, 09:52 PM   #6
Rewards Points: 3,352
This stuff works, used it 3 years ago and still going strong, and you don't have to remove all the rust.
http://www.homedepot.com/p/Rust-Oleu...5215/100392541
Canarywood1 is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Re-anchoring Wrought Iron Railings garyhomeowner Building & Construction 4 04-20-2010 09:10 PM
Oak hand rail on existing iron stair railing SHREDTHESYSTEM Carpentry 9 03-22-2010 06:30 PM
Repainting Railings drewdc Painting 3 07-11-2009 09:19 AM
