Painting Interior Window Framing - Painting - DIY Chatroom Home Improvement Forum
Old 07-12-2010, 12:13 PM   #1
Painting Interior Window framing
I just purchased a new condo. It was gut-rehabbed in 2007. Whoever the painter was, did an average job. I'm in the process of painting all the rooms - one at a time.
1. The window boxes are about 9 inches deep on the interior of every window. The knots from the wood have stained through what looks to be like a white semi-gloss latex paint. I've read to use an acrylic based sealant to prevent knots from bleeding through, but I don't know what to do since the surface is already painted. My budget is not huge, so I don't have the luxury of hiring someone or re-doing all of the window boxes.
2. Can I paint my bathroom ceiling the same color as the walls? The bathroom is large, 10x12' with 10' ceilings. We are looking into a VERY soft light blue. I've already read the threads about bathroom paint and I plan on using it. Just wondering how many requests you get to paint ceilings the same color.
Thanks in advance - I'll check in to answer any questions you may have.
kevindragotto is offline   Reply With Quote
Old 07-12-2010, 05:57 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
You need alcohol based Shellac for wood knots. Anything less will eventually bleed through.
Paiting the ceiling the same color as the walls is up to you but it can make the room seem smaller.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Tom Struble (07-15-2010)
Old 07-15-2010, 09:22 PM   #3
General Contractor
Shellac is the best primer around for covering up knots. Use a quality latex or acrylic paint for the top coats.
developer-gspr is offline   Reply With Quote
Old 07-15-2010, 09:36 PM   #4
Can I apply the shellac directly over the paint it has now?
Old 07-15-2010, 10:47 PM   #5
General Contractor
I don't see why not. Maybe lightly sand it first for adhesion.
Old 07-16-2010, 03:08 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
Yes, Bin in a spray can or quart is what you need.
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
ARTWORK-STRETCHING, FRAMING A CANVAS painting suziemaus Interior Decorating 3 07-19-2008 09:28 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
