Painting Interior Trim - Painting - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 01:23 PM   #1
Painting interior trim
Hi all,
Is it necessary to paint all sides of interior trim before you install it? Even the back side that you don't see?
I'm installing a 1x6 Pine ledge over a knee wall. It's a 9ft length of pine, and I'd rather not see it warp 6 months after installing it.
Will painting all sides make interior trim more stable or am I just wasting paint?
mfc133 is offline   Reply With Quote
Old 05-02-2011, 11:35 PM   #2
Originally Posted by mfc133 View Post
Hi all,
Painting the whole thing would keep the moisture content of the wood more stable, so it would be less likely to warp. However, don't expect miracles from pine. Be sure to prime it well if it has knots or those will bleed thru just about any paint. They make hardieplank in 1x6
Robo_geek is offline   Reply With Quote
Old 05-03-2011, 06:36 AM   #3
It wouldn't hurt to prime all six sides, but it won't hurt if you don't. Exterior, absolutely prime as much surface as you get access to. BTW, prime the knots, if any, with BIN pigmented shellac. In fact, you can prime the whole board with BIN. Outside, no, BIN is only a spot primer.
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
painting my mom house supaflyz Painting 5 07-28-2009 02:34 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
