Old 03-07-2007, 04:05 PM   #1
Question
Painting Interior Hollow Core Doors
I've grown tired of the wood hollow core closet and room doors and I want to repaint them.
I suspect that they are an oak wood veneer and won't hold up to much sanding.
What steps must I take to prep the doors and will a satin semi-gloss paint be ok?
shapeshifter is offline   Reply With Quote
Old 03-07-2007, 05:38 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
A light scuff sanding is fine
Then clean well, with a tack cloth
If they are in good shape and not too dark, an oil-based primer should work just fine
Very dark, or questionable shape/quality, a pigmented shellac would be better
Then two coats of quality latex
For the best in durability and cleanable-ity (doors get abused and get dirty quickly), I'd recommend a waterborne enamel
Ben Moore's Satin Impervo is my favorite, though I hear from trusted sources the Sherwin Williams Pro Classic is pretty good too
slickshift is offline   Reply With Quote
Old 03-07-2007, 06:06 PM   #3
Talking
Thanks for the info, Slick. I used SW on the walls in that room and I was impressed. I'm trying to get r.. use up of the rest of my AT "Navaho White" and no, pouring in a hole is not an option
SW says they can make up some more Navajo White for me, all I have to do is take the bucket in with me next time.
Old 03-07-2007, 11:01 PM   #4
slickshift's Avatar
Ah I see, proper prep and prime and that'll work just fine
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
Attic Doors cyepsen Building & Construction 3 06-24-2007 07:47 AM
Painting interior doors and baseboard bdalekid Painting 4 03-30-2007 10:06 PM
Painting Old Hollow Doors diywoman Painting 12 02-02-2007 07:52 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
