-   -   Painting Interior Hollow Core Doors (http://www.diychatroom.com/f4/painting-interior-hollow-core-doors-6949/)
shapeshifter 03-07-2007 04:05 PM
I've grown tired of the wood hollow core closet and room doors and I want to repaint them.
I suspect that they are an oak wood veneer and won't hold up to much sanding.
What steps must I take to prep the doors and will a satin semi-gloss paint be ok?
:huh:
slickshift 03-07-2007 05:38 PM
A light scuff sanding is fine
Then clean well, with a tack cloth
If they are in good shape and not too dark, an oil-based primer should work just fine
Very dark, or questionable shape/quality, a pigmented shellac would be better
Then two coats of quality latex
For the best in durability and cleanable-ity (doors get abused and get dirty quickly), I'd recommend a waterborne enamel
Ben Moore's Satin Impervo is my favorite, though I hear from trusted sources the Sherwin Williams Pro Classic is pretty good too
shapeshifter 03-07-2007 06:06 PM
Thanks for the info, Slick. I used SW on the walls in that room and I was impressed. I'm trying to get r.. use up of the rest of my AT "Navaho White" and no, pouring in a hole is not an option :laughing:
SW says they can make up some more Navajo White for me, all I have to do is take the bucket in with me next time.
slickshift 03-07-2007 11:01 PM
Ah I see, proper prep and prime and that'll work just fine :wink:
