Old 06-30-2012, 03:10 PM   #1
Painting interior doors
Painting interior doors what paint is the best paint? So it adheres well, covers, and does not scratch off.
melly5754 is offline   Reply With Quote
Old 06-30-2012, 07:36 PM   #2
The answer depends on how much prep you are willing to do.
You should always sand to provide tooth for the new paint.
I recommend sanding using wet dry sand paper with water.This is a safe method even if there is lead paint on the door.
Clean with clean water and sponge and when dry wipe door with denatured alchohol.
You can then prime with an acrylic(Zinsser 123) or oil primer (benjamin Moore alkyd underbody)depending on preference to smell and mess.
The finish coats should be brush finished oil.
The higher the sheen the more durable the finish.
The most poular and a great finish is ...Benjamin Moore Satin Impervo oil.
My doors are painted 15 yrs and still look good.
kilmacaran is offline   Reply With Quote
Old 07-01-2012, 06:01 PM   #3
Are you from Kilmac?
Old 07-01-2012, 06:17 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
.. good advice up to the "should" be finished in oil. Great advice- for 15 years ago.
Even in the last 5 waterborne finishes have come a long way. Many good choices- some bad ones..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-01-2012, 09:19 PM   #5
Thank you for your response. It was exactly the advice I needed. I want to make sure I do this project right the first time. I have nine doors and four double door closets.
Brushjockey, Which "waterbourne" finishes do you recommend? Please be explicit on the exact type of paint. Thank you,
Old 07-02-2012, 05:34 AM   #6
paper hanger and painter
chrisn's Avatar
Sherwin Williams pro classic or Ben Moore. Satin Impervo,waterborne
Old 07-02-2012, 07:42 AM   #7
sdsester's Avatar
Yup And use nice tools like decent brushes to start.
As mentioned, most of the task ahead of you and its outcome depends on the prep.
sdsester is online now   Reply With Quote
Old 07-02-2012, 08:43 AM   #8
Those are good'ns. To that list I would add Muralo Ceramic Satin or Semi, BM Aura Satin, BM Advance, there are some smaller regional co. that make good product like Dunn Edwards, Ace hdwr carries Cabinet Coat that I hear is very good.
Read up on applying waterborne finishes. They sometimes are helped by adding an extender to slow drying and make brushing easier.
The main advice is go to a real paint store- you will get better product and ( usually) more informed info.
Old 07-02-2012, 07:10 PM   #9
Phil - "the Paint Guy"
Good advice but always wipe down the door first with denatured alcohol, allow to dry, sand, the wipe down again with denatured alcohol again. The denatured alcohol helps to remove any surface contaminants that could interfere with adhesion. Sanding without a denatured rinse may grind in and spread waxes, oils and cleaners into the existing paint causing adhesion issues.
Good luck,
Phil "the paint guy"
Cpcphil is offline   Reply With Quote
Old 07-04-2012, 12:45 PM   #10
Thanks to you all!!! This is exactly what i needed, will take all the advice to use, and will let you know how it goes. Mending a fractured ankle right now, but thought i would get the right information and do this right the first time!! Happy 4th of july to you all!! Happy home improvements!
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
