Painting Interior Of Car( Some Plasctic Some Vynal) - Painting - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 06:24 PM   #1
Unhappy
painting interior of car( some plasctic some vynal)
hi here is my problem . i painted my cenet consloe and it turned out great. then i decided to paint a section on my door pannels to match. turn out great to the eye ... but even a few days later its still tacky to the touch .. why wont it dry ?? what do ineed to do to get this spray paint to finnaly dry ????
pureprestige is offline   Reply With Quote
Old 10-21-2008, 06:48 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
For plastic and vinyl you need to use the proper paint. Regular old spray paint has some issues. You'd be better off going to an automotive store and asking for a product called Plastikote. It's a vinyl dye in a spray can. Humidity could be keeping the current paint from drying. If it's on plastic or vinyl is doesn't really have a place to soak into.
poppameth is offline   Reply With Quote
Old 10-21-2008, 06:51 PM   #3
the Musigician
DangerMouse's Avatar
it's possible that smoke/dirt/oils built up on the door panel could do this. how well was it cleaned first?
DM
Old 10-21-2008, 09:06 PM   #4
it was cleaned sanded and primered and im using the same paint as i did on the plastic and it dried and looks good .. just having problems with the vynal paint is ....painters touch by rustoeum .. wood metal wiker plastic and more
Old 10-22-2008, 05:11 AM   #5
the Musigician
i've had some success with spraying a clearcoat over non-drying paint. if it's a similar type paint, this may help. it may also take longer to set anywhere you've touched it. (skin oils) you may need to remove/strip the panel and start over with another type of paint.
DM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
