Painting Inside Window - Painting - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 07:48 AM   #1
painting inside window
Everything in the kitchen is oak, oak and more oak. Can I paint the inside OAK window to break up the cabinet, window scheme. I was thinking of painting the window white or a cream to match the walls when I paint them. The window in set between 2 oak cabinets. UG...so much oak
Thanks so much!
citygirl is offline   Reply With Quote
Old 02-13-2011, 09:20 AM   #2
Super Master Painter
Ole34's Avatar
sure as can............i would, oak to the sides, white in the middle looks great
Ole34 is offline   Reply With Quote
The Following User Says Thank You to Ole34 For This Useful Post:
citygirl (02-13-2011)
Old 02-13-2011, 09:22 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 676
Send a message via Skype™ to AndyGump
Sure you can paint the oak.
Why would you question whether or not you could?
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Old 02-13-2011, 09:28 AM   #4
why wouldnt you paint over oak, less is more with this material imho
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
Old 02-13-2011, 11:34 AM   #5
Ole34's Avatar
white window with oak frame looks good also
Old 02-13-2011, 12:14 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If you are going to be painting oak you will want to first prime it with an oil base primer, otherwise the water from the latex paint can raise the grain.
housepaintingny is offline   Reply With Quote
Old 02-13-2011, 01:45 PM   #7
I agree with everyone, and will expand on housepaintingny to recommend a bonding oil primer, such as cover stain, or BIN shellac. This will cover the bases in the event a proper scuff, over what's probably clear coated, isn't achieved.
Joe
DiyPaintingGuide.org
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
PT 2x4's as window trim - painting when wet ? Cossack Painting 7 08-24-2010 11:33 PM
Cleaning the inside of a double-pane window Smac Remodeling 3 06-11-2010 11:23 AM
Painting interior of vinyl bay window? blakekr Painting 2 02-11-2008 08:30 PM
