Painting House Exterior - Painting - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 02:11 PM   #1
painting house exterior
Hi There
First visit of many I hope...my son is about to re-paint, the bottom 4 courses of bricks on his house exterior, it is red, and he intends to do same.
My advice was to give it a good rub down, even a wire brush if needed, give it a coat, or two of bonding (think it's PVC?) which will act as a sealer, and act as an adesive.
Is my advice correct please
frenchman96 is offline   Reply With Quote
Old 11-05-2011, 04:30 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
You in France?
Old 11-05-2011, 06:41 PM   #3
Non mon ami
Old 11-06-2011, 04:59 AM   #4
chrisn's Avatar
Rewards Points: 232
Bien, pour répondre correctement, nous devons savoir où vous êtes. Au moins dans la paire cent miles.
Old 11-06-2011, 10:36 AM   #5
Hi
I am a scouser, not French, so only understood part, and the link did not help sorry?
Old 11-06-2011, 10:57 AM   #6
Gymschu's Avatar
Rewards Points: 486
If the brick is in pretty sound shape, a repaint is all that's necessary. After scraping/wire brushing the brick and maybe even a gentle wash and dry, apply 2 coats of your favorite Satin or Semi-gloss paint. A masonry primer could be used to spot prime the bare spots. You can prime the whole thing if you feel it's necessary. Pretty straightforward.
Old 11-06-2011, 10:27 PM   #7
Were you up all night learning that?
Old 11-06-2011, 10:39 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
Chris is enfaranche, who knew??!!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-07-2011, 06:12 AM   #9
chrisn's Avatar
Rewards Points: 232
Well, to answer correctly, we must know where you are. At least with in a couple hundred miles'
Loose tranlation.
I had 4 years of French in high school, but I really used a translating tool for this
It seems like the question was answered ,but at least here, it is way to cold
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 08:56 PM
Painting the exterior of a house rcoope1 Painting 5 06-04-2011 03:56 PM
Painting house exterior MVW Painting 9 11-06-2010 09:01 AM
1st time exterior painting a house, need suggestions/tips/advice Funkdrspot Painting 22 05-17-2010 10:52 AM
painting my mom house supaflyz Painting 5 07-28-2009 03:34 PM
