Painting Of Green Sheetrock In Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 11:32 PM   #1
Wink
Painting of green sheetrock in bathroom
We are having a problem getting the paint to stick on the green sheetrock that is in our bathroom above the tile in the shower area. Is there some kind of product that you paint onto the green sheetrock to get the paint to adhere to it? Also do we need to use a special kind of paint in the shower area? or put a coat of something that will prevent it from coming off after so much moisture and steam?
Jacque is offline   Reply With Quote
Old 10-10-2010, 12:06 AM   #2
pva or new drywall primer goes over the texture you sprayed on. if you don't do this it will soak up paint like crazy. you'll go from needing 2 coats to 3 or 4
they make special bathroom and kitchen paint that's oil based and a bit more rugged. if you have a sherwin williams near go in and they will walk you through the process
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
Jacque (10-10-2010)
Old 10-11-2010, 11:46 PM   #3
logistics
jack pauhl's Avatar
If you already painted the greenboard and that paint is not sticking then you have a bigger problem a coat of new primer will not fix.
What exactly do you have going on right now? Do you have green board or painted green board and what did you try applying to it?
jack pauhl is offline   Reply With Quote
Bathroom and textured ceiling painting? elementz Painting 6 10-01-2010 04:27 PM
Painting mess in my bathroom slt Painting 15 01-06-2010 05:45 PM
painting a dresser for a bathroom cindyb861 Painting 12 02-02-2009 06:19 PM
painting bathroom - primer for greenboard and hardiebacker? carrotguy Remodeling 5 06-23-2008 02:50 PM
painting sheetrock camillel1 Painting 1 05-30-2008 03:21 PM
