Painting Gas Fireplace - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 10:33 AM   #1
Painting gas fireplace
I'm painting the inside of my bas burning fireplace ( the firebox). What paint have others used for this? I've read that some people had bad experiences with paints giving off a fume when the fireplace was used after painting the firebox.
I'm putting in a gas "log" - actually just a gas burner covered with sand to distribute the flames and glass over that for a modern look. The flames will not be touching the firebox at all.
We are also refacing the wall with a modern tile. I'll post pictures soon.
Softwareguysf is offline   Reply With Quote
Old 05-05-2013, 11:41 AM   #2
Too Short? Cut it Again!
Well it should not get too hot but to be safe I would use a high heat paint (and self-etching primer if the metal needs it). You can get engine enamels in black, white and of course colors.
Rustoleum and Krylon both make a high heat barbecue and radiator paint in black or white (and some deep colors) that should do the trick if that fits with the look you have in mind. I would mask off what you don't want painted and use rattle cans for this. You can buy high heat paint in liquid form too though.
Painting mortar on brick fireplace MsKitty32 Painting 13 02-08-2013 09:24 PM
Painting fireplace mantel and surround asbury park Painting 8 02-21-2012 04:21 PM
anyone tried Brick-Anew for painting a fireplace??? BusyMom Painting 75 11-01-2010 09:08 PM
Painting over an oak fireplace mantle kitlin Interior Decorating 0 04-25-2010 07:38 AM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
