Painting Floor Molding - Painting - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 12:49 PM   #1
Question
Painting floor molding
What type of paint should be used on floor molding (pine quarter round specially), in a tile kitchen or bath. The last stuff I used is now peeling off because it gets wet when the floors are mopped. I believe the type used before was a high gloss white enamel, and the molding was primed before hand. Want to redo, but want to use a paint to prevent this happening again.
Thanks for any help.
Mjkast is offline   Reply With Quote
Old 03-30-2013, 01:15 PM   #2
The problem is not so much the paint, but the fact that water is getting under the quarter round. I doubt the underside of the trim is sealed. The water gets under it, is wicked into the bare wood, and then pulled through the front taking the paint with it. I faced a similar problem with quarter in a bath, and where it butted the tub on both ends there was continual peeling. I caulked the quarter to the tile floor and that solved the problem. You'll need to bring the paint out over the caulk by 1/16th to protect it and prevent it from collecting dirt. Either that or pull it and replace with a new non-wood, synthetic, quarter that will not absorb water.
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (03-31-2013)
Old 03-30-2013, 05:47 PM   #3
i paint all my base and shoe molding with benjamin moore impervo oil based.
Old 03-30-2013, 06:33 PM   #4
Roofmaster
Rewards Points: 2,210
In the kitchen you might want to use vinyl cove molding, and in the bathroom a vertical bull nose tile. These will hold up to wet mopping much better.
Old 03-30-2013, 06:40 PM   #5
Rewards Points: 14,278
For this to happen you would have to be using way to much water when washing that floor.
Old 04-03-2013, 01:01 PM   #6
Learning every day
Rojo68's Avatar
This ^^^^^^
Rojo68 is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
