Old 01-21-2013, 11:25 AM   #1
Painting fireplace surround...thoughts on coverage?
I'm paintings fireplace surround that previously had a wood finish with probably sone varnish. I sanded the shine off it, primed with Zinsser 123 and am now laying on a coat of SW Pro Classic Extra White Satin. After the first coat I'm seeing some of the pores on the wood grain. Doesn't look bad, but you can see them. Will this cover with a second coat,
asbury park is offline   Reply With Quote
Old 01-21-2013, 01:16 PM   #2
If it's oak, the grain will probably stay there. Otherwise, it ought to be gone with another coat or else something is a little strange or not quite done right.
jeffnc is offline   Reply With Quote
Old 01-21-2013, 05:57 PM   #3
Laid the second coat. Much better but not complete coverage. Still see a little wood coming through. I think one more coat will do the trick. In retrospect, maybe two coats of primer would have been a good idea.
Old 01-22-2013, 04:51 AM   #4
paper hanger and painter
chrisn's Avatar
not really
Old 01-22-2013, 05:18 AM   #5
2 primer coats not a good idea? Always 1?
Old 01-22-2013, 06:28 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
chris- explain why. I hate to do clean up after you!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-22-2013, 07:57 AM   #7
cdaniels's Avatar
You put the 1-2-3 on so that the paint has a surface it can bond to.You don't need to put on two coats of it because one coat accomplishes this.That is all it is there for.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 01-22-2013, 08:43 AM   #8
Gymschu's Avatar
Like someone stated earlier, the grain of the oak is gonna show through no matter how many coats you apply. Why anyone paints beautiful oak is beyond me. One coat of primer is ALWAYS enough. Primer is a problem solver. You applied a bonding primer to bond to the old varnished oak. Problem solved. Now if you were worried about the grain situation, you may be talking about filler and sanding, etc........a whole different problem.
Old 01-22-2013, 05:36 PM   #9
chrisn's Avatar
Ha, the last two guys did that for me, thanks guys.
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (01-22-2013)
anyone tried Brick-Anew for painting a fireplace??? BusyMom Painting 75 11-01-2010 10:08 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 03:57 AM
Brick Fireplace Painting asuka Painting 27 12-13-2008 10:53 PM
painting over a brick fireplace lindalouthehandygirl Painting 1 07-24-2008 03:41 AM
Tub Surround, Painting, Durock or Greenboard, and Spacking Questions? golfer2b Plumbing 7 04-17-2008 09:59 PM
