Old 09-18-2006, 03:40 PM   #1
painting filled crack in bath
Hi i have used a bath repair kit to fill a crack in the fibreglass of my bath. I had gone with the soft cream option as it was that or white, but the spray paint is too creamy and needs to be a duller green to match the suite. Any ideas for either altering what i have or buying new to match. Also any tips for painting or respraying it would be welcome as i'm a complete plank lol.
zoodemon is offline   Reply With Quote
Old 09-19-2006, 01:08 PM   #2
Did you match the color before applying?
where is the location of the crack? On the side or on the bottom?
redline is offline   Reply With Quote
Old 09-19-2006, 01:53 PM   #3
They're all fixer-uppers
J187's Avatar
I'm confused are you using a gelcoated paint that came w/ the repair kit? Sometimes the best way is to call the manufacturer of the tub. They can usually do one of two things.
Send you a bottle of touchup paint.
Refer you to the brand and color code of the paint they use. Which you can then in turn take to a place that does glazing or porcelain patching and they can match it.
J187 is offline   Reply With Quote
Old 09-19-2006, 02:31 PM   #4
the crack is on the front lip of the bath, and i have filled it with the filler with hardener. The kit's only came in white or soft cream colours, and the cream is too creamy in colour.
Any idea how i find the manufacturer of the bath??
thanks
Old 10-02-2006, 03:31 PM   #5
any other ideas on mixing paint to put on fibreglass bath. the bath itself is presumed an import so has no makers markings. I just have to mix up some paint for the job somehow????
thanks
Old 10-02-2006, 08:16 PM   #6
Long-Time DIYer
Mike Swearingen's Avatar
I would use acrylic paint, marine paint or white appliance enamel "touch-up" repair liquid.
I've always just used the "bright white" enamel touch-up repair liquid for my white tub/shower units. It doesn't exactly match (whiter), but it drys hard as a rock. It can be found at many appliance stores.
Clean the scratch, crack or ding with acetone (nail polish remover).
Dry it with a hair dryer. Apply the touch-up liquid and smooth up the edges with a Q-tip dipped in nail polish remover.
Let dry overnight. It shrinks a bit, so you may have to apply two coats. Works for me.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-05-2006, 12:33 PM   #7
Can you tell me what the name of the kit was as I have a crack in the bottom of my tub I have to fix.
pigger63 is offline   Reply With Quote
Old 10-06-2006, 05:15 PM   #8
cramer bath repair kit. it's available in white and cream from plumbworld.com
when you said crack in the bottom of your tub, i immediately wondered if you want something more substantial. if it's superficial this should be ok. i warn you the paste dries fast though.
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
Hairline Cracks after painting parasailing Painting 8 07-24-2006 12:47 AM
Novice: Painting lighter colour over darker psd99 Painting 5 01-18-2006 09:24 PM
Unidentifiable pipe/vent in bath Hobiedog Plumbing 1 12-02-2005 06:33 PM
