Painting Fiber Cement Siding - Painting - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 06:26 AM   #1
Painting fiber cement siding
I am replacing the siding on my house with Hardieplank Cedarmill fiber cement siding and would be interested in recommendations regarding type of paint to use. The only recommendation from James Hardie is not to use stain, only 100% acrylic topcoat. Is there a particular brand of paint that works better on fiber cement siding or are all of the premium brands (BM, SW, PPG etc.) comparable? Also, would it be beneficial to re-prime before topcoating even though it's already pre-primed?
david.plymouth is offline   Reply With Quote
Old 09-06-2009, 10:18 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
Yes all top of the line 100% acrylic paints are pretty much the same.
If it were me I would re prime ALL 6 sides, then you know it was done right.
Old 09-06-2009, 10:53 AM   #3
Thanks Chris, do you think it's worth using a concrete & masonry primer rather than a regular latex primer? I was thinking of using Sherwin Williams Loxon primer.
David
Old 09-06-2009, 03:18 PM   #4
The only thing I would add is, putty all nail holes, and then prime nail putty with a oil base paint so water doesn't get to nail heads and cause them to start rusting under the new paint out.
Then finish as Chrisn stated above.
LouLewyLewis is offline   Reply With Quote
Old 09-06-2009, 05:23 PM   #5
chrisn's Avatar
Rewards Points: 388
David
You got it
Old 09-06-2009, 05:25 PM   #6
Any reason your aren't getting them pre-painted?
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 05:08 PM
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-24-2009 11:17 PM
Primed fiber cement siding and water/rain Scott99999 Building & Construction 2 06-13-2009 08:53 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
