Painting Fake Oak Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 10:31 PM   #1
painting fake oak cabinets
i have a 1999 manufactured home and want to paint the cabinets in bathroom.im not sure what you call it but they have a covering on them that looks like oak wood.can i do something to paint over it?
GLASSMAN1 is offline   Reply With Quote
Old 01-31-2008, 09:19 AM   #2
Rewards Points: 506
You will need to thoroughly clean them with a strong detergent, like TSP, coat them with at least an oil-base, and preferably a shellac-based primer, and then you are ready to go to topcoat with the quality enamel of your choice.
SirWired
sirwired is offline   Reply With Quote
Old 01-31-2008, 06:57 PM   #3
Thank You Very Much For Your Reply.
Old 01-31-2008, 08:07 PM   #4
annabell's Avatar
Hello, Would it be necessary to lightly sand them first. I have to same cheap particle board cabinets. It would almost be better to not have any at all.
annabell is offline   Reply With Quote
Old 01-31-2008, 08:36 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
If that is the "wood laminate" that is more like wood-look paper over particle board, then I do have a specific suggestion
If the quality is questionable, like that the scuff sanding makes a mess of the "laminate" and starts pulling the paper up, I'd skip the scuff sanding step
If you can get away with a very light sanding, just a little scuffing, then do it
It's a judgment call though, try a test area first
Clean with an ammonia based product-do not use TSP
Ammonia/water or ammonia based window cleaner....either/or
After they dry fully, then use a light coat of pigmented shellac primer/sealer
I can recommend Zinsser's BIN
Keep it light, as too much moisture can lift this questionable substrate (the wood paper)
After that dries, then you should have a nice base upon which to do your painting
I'd recommend an enamel, either waterborne or oil-based, whichever you prefer
I can recommend Benjamin Moore's Impervo or Sherwin Williams Pro Classic as top quality enamels
slickshift is offline   Reply With Quote
Old 02-01-2008, 06:48 PM   #6
annabell's Avatar
awsome thanks.
painting knotty pinewood kitchen cabinets sil Painting 2 10-16-2007 09:07 PM
Painting Kitchen Cabinets (part 2) - Which Paint Gun/Sprayer? 1655graff Painting 5 10-05-2007 11:10 AM
Worth removing the cabinets before painting my kitchen? J187 Painting 7 10-08-2006 08:02 PM
Painting Kitchen Cabinets bgillette79 Painting 1 09-08-2006 05:31 AM
painting old cabinets pdagosta Painting 9 08-11-2006 09:16 PM
