Painting Exterior Window Sashes - Painting - DIY Chatroom Home Improvement Forum
Old 10-24-2009, 07:34 PM   #1
Painting exterior window sashes
I don't often do these .
My main issue is what type of primer to use on the putty.do u recommend oil based or water based.I find that the weather really taxes the putty part, especially the bottom part of the frame.
give me a run down on how you paint them.
cheers.
nerd_flanders is offline   Reply With Quote
Old 10-25-2009, 04:12 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Remove all loose glazing, prime with slow dry oil, replace glazing, let it skim over a couple days, prime again with slow dry oil, let dry onernight, apply 2 exterior topcoats of 100% acrylic.
Old 10-25-2009, 05:54 AM   #3
Too Short? Cut it Again!
Don't forget to clean the glass. Insert new or additional glazing clips if needed. Make sure it is an alkyd primer (solvent/oil-based) so the latex will stick. It is really important to prime before reglazing as Chris suggests. And try the glazing putty for caulking guns---especially if you have a lot of glazing to do. It really makes the job go faster.
Old 10-25-2009, 06:31 PM   #4
painting sashes
glazing putty in a caulking gun,. easy there buck rogers , we don't have that technology in our country.
maybe glaziers have it I don't know .
what does glazing putty have added to it apart from putty?
Painting exterior sashes nerd_flanders Painting 6 08-12-2009 08:31 AM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
