Painting Exterior Window And Door - Painting - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 12:22 PM   #1
painting exterior window and door
I am painting a new white fiberglass door and window (exterior). We live at the beach with a lot of weather and wind. No direct sunlight to this area. What do you recommend. Manufact. says acrylic latex but what brand. The surface seems slick so do I need a primer. The inside of the window is wood do I need a primer and different paint for this also. thanks for any assistance
steve hof is offline   Reply With Quote
Old 10-27-2008, 09:03 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Duration, Accolade, Aura. All these are good paints for this application. They dry to a good hard finish that shouldn't stick in the frame and will give you the greatest longevity.
poppameth is offline   Reply With Quote
Old 10-29-2008, 08:00 AM   #3
You might want to scuff sand the door and window. Paint doesn't like to adhere too well to glossy surfaces. If you want to make the job last, prime with a premium primer like XIM 400W before you topcoat. 400W just doesn't scratch off after it has cured and makes a great bonding primer for the topcoat.
Tommy Boy is offline   Reply With Quote
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Painting a sliding closet door javan Painting 1 06-25-2008 10:47 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
Help with painting an interior door Kim Painting 2 03-05-2005 12:38 AM
