Painting Exterior Door Trim - Painting - DIY Chatroom Home Improvement Forum
Old 05-12-2007, 07:56 PM   #1
Painting exterior door trim
I am looking to paint exterior door trim. Whats the best type of paint, I would like to stick with BM paints. Please advise , Thanks to all.
helpless handyman is offline   Reply With Quote
Old 05-12-2007, 08:25 PM   #2
Pro Painter
Something along the line of superpaint or duration for SW products.
BM has good products for this too.
Exterior door trim aka brick mold is an area that needs special attention at least once during it's lifespan.
After sanding and cleaning, it should be thoroughly inspected for clear silcone caulk and other contaminants that will prevent good paint from doing it's job.
Often times, it's necessary to cut away caulks or puttys in order to get good primer/paint adhesion.
Hope this helps.
joewho is offline   Reply With Quote
Old 05-12-2007, 09:05 PM   #3
Thanks, but am I looking for oil paint, or water base? Also BM, which one? Thanks again!
Old 05-13-2007, 01:23 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
Moore Glow or Soft Gloss
Go with whatever type is on there now (oil/latex)
They'll show you the right one in the Ben Moore dealer
Probably latex unless it's pretty old paint
You can test it with some Oops! or Goof Off!
If you can wipe it off on a rag with that stuff, it's latex
slickshift is offline   Reply With Quote
Old 05-22-2007, 11:04 AM   #5
I'm also painting some window and door trim. I'm using SW superpaint and can't recommend it highly enough. It is fabulous!! My question is after I strip the old paint off of the window frames and door trim, is it necessary or even advisable to wipe some sort of protectant or presevative on the bare wood before repainting? I think I've heard of people using linseed oil but it seems like that would interfere with adhesion. Any advice would be greatly appreciated!! Cheers!!
chuckfarley is offline   Reply With Quote
Old 05-22-2007, 03:05 PM   #6
slickshift's Avatar
Trim scraped to bare wood needs to be primed before repainting
Old 05-22-2007, 05:03 PM   #7
I also believe SW Superpaint is an interior paint, so it wouldn't be a good option for outside.
DIYHelper is offline   Reply With Quote
Old 05-22-2007, 06:17 PM   #8
slickshift's Avatar
They've got an outdoor one too
Both Int/Ext SuperPaints are too drippy for my tastes
painting my floor Eli Flooring 3 03-20-2011 04:11 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Painting over wallpaper RussellF Painting 8 11-01-2006 01:42 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
