Painting A Exterior Decking - Painting - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 09:46 AM   #1
Painting a Exterior Decking
HI -
Need to have our deck painted. The painter is telling us that since the deck wood (pressure treated) has been sitting around for about 6 months that we need to have it pressure washed to remove all the grey (old) wood or it will peel in a year...
Never knew this. Is he full of it???
Also..one or two coats?
He recommends two with a semi-solid paint to last a lot longer and BenMoore paint.
Professional advice needed!!!
Thanks in advance!
CheriAlli is offline   Reply With Quote
Old 09-26-2012, 09:50 AM   #2
Gymschu's Avatar
Rewards Points: 662
Plenty of info available on here. Use the search function and you will find 7 or 8 current topics on this very subject.
It definitely needs cleaned before being stained..........DO NOT PAINT IT. Pressure washing tends to damage wood decks although in the right hands it can be done properly. That GRAY color is actually mildew, dirt, mold, etc. and your painter is right.......you can't just throw stain over top of dirt. Once cleaned allow it to dry for several days. Then you can apply a quality semi-transparent stain. DO NOT PAINT YOUR DECK!
The Following User Says Thank You to Gymschu For This Useful Post:
CheriAlli (09-26-2012)
Old 09-26-2012, 09:55 AM   #3
Thanks for the speedy reply and the info.
Much needed and just in time to schedule him for the job!
Old 09-26-2012, 05:03 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
Originally Posted by CheriAlli View Post
HI -
Thanks in advance!
huh?
Old 09-26-2012, 05:21 PM   #5
Rewards Points: 13,456
No such thing as semi solid paint.
He must have been talking about stain instead.
Old 09-26-2012, 09:33 PM   #6
yes sorry that's what i meant.
Old 09-27-2012, 03:50 AM   #7
chrisn's Avatar
Rewards Points: 312
ok got it
Old 09-27-2012, 05:13 PM   #8
Too Short? Cut it Again!
I suspect he is recommending a semi-solid stain to blend in any discoloration? The closer you can get to a semi-transparent stain that would do the same thing the better though. The more solid the stain the more pigment is going to stay on the surface and the faster it could wear.
It is hard to tell what your deck looks like but take a look at some semi-transparent color charts?
The Following User Says Thank You to user1007 For This Useful Post:
CheriAlli (10-09-2012)
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
